295/70r18 vs 285/75r18
Thanks.
I’ve got a set of 285/75/18 waiting for me. Just trying to determine if they will fit on factory ride height, or if I need my level kit put on first.
Was hoping to do tires then level, so I could hsve shop align post level.
Anyone know if 285/75/18 fits on factory wheels no level?
If you plan on off-roading IMO, no. If you are only street. Very little off-roading, I’d say they should be okay. Going with the 295/70r/18 isn’t much smaller and it works in all conditions
I'm specifically trying to choose between Falken Wildpeaks 285/75R18 or 295/70R18. My Grabbers have around 36k on them and I'm in need of an upgrade. I plan on switching to Eibachs coilovers but I'm going to wait for their 2.5s to come out. You think the 295/70s would fit better at stock height?
I was going to get Falcon's until I found out the 295's are made in China. No thanks. Went with M/T Baja Boss A/T. Only negative is they are HEAVY. But look awesome and are silent.
I was going to get Falcon's until I found out the 295's are made in China. No thanks. Went with M/T Baja Boss M/T. Only negative is they are HEAVY. But look awesome and are silent.View attachment 36176View attachment 36177
More pics with those!
Tbey are almost double the weight of grabbers. How much can you tell with acceleration, stiffness, braking, mileage?
Curious if the 305s will rub or if the stock wheels are too narrow.
Accel is slower for sure. MPG went from 16-ish to 14-ish. stiffer yes, but air is at 37. I need to drop them and see how they ride. Braking slower too. But they look bad ass, are quiet, and great in snow slop and wet roads. 74 pounds vs the stockers which were about 20 less.
Let us know how the ride is with lower air.
Did you consider the 305 at all?
I was going to get Falcon's until I found out the 295's are made in China. No thanks. Went with M/T Baja Boss A/T. Only negative is they are HEAVY. But look awesome and are silent.View attachment 36176View attachment 36177
Yeah I have the 295 Baja boss on a 17 and it’s 72lbs, you can feel it when you get on the gas. Upside is these tires are the most durable i’ve ever wheeled. I’m not worried about getting a flat at all.
Will do. I ruled out the 305 as they’re not rated for a 7.5” wheel.
PNW, what pressure are you running? Discount tire pumped mine up to 37.
Long roadtrips I do about 40-45 just to save 1/4 mpg or so.
Around town I’m sitting at 35 on all 4.
I've got the Recon 290's and they look great. I do have a slight rub at full lock. Had them for less than 5K on my 22 Tremor, so just moved them over to my 24. Didn't notice much MPG in my 22 (it was eco); I swapped upon delivery so I didn't have the factory tires on the 5.0 to compare.
Which size and tire is this
I ended up going with BFG KO3 295/70R18. Fit is great and no rub without any modifications. They were cheaper than the Falkens. Loving them so far after a couple thousand miles.
Looks good. Why this size over 286/65
Bc I didn't want to modify my suspension, like big tires, and do off-road stuff. These are as close to 35s (34.5ish) that I could get without rubbing.
