Brynn2023Tremor
Perfect thx!I don’t have a video for ecos, but I have some detailed pictures of the process.
They are a Canadian company!Link can’t seem to find them anywhere on the interweb?
nightriderleds.com
Are there any suggestions for the 2025 Tremor modular bumper?Before and after. Got my brack lights and harness installed last night. Have to wire up my switch harness to the truck and should be good to go. I think it took me about 3 hours start to finish but its not a bad install at all. Ive not taken one of these trucks apart before so i was taking it easy with all the plastic parts. These trucks were not designed for someone with large hands to work on them lol.
Lots of options for the mod bumper! 4 pods is the cleanest setup.Are there any suggestions for the 2025 Tremor modular bumper?
YessirDoes the SS5 fit?
I'm not sure about that.Does the SS5 fit?
Definitely a different lookI'm not sure about that.
Yeah, also wondering if anyone has done a complete light bar instead of individual pods? https://www.diodedynamics.com/ss10-sae-dot-yellow-led-light-bar-one.htmlDefinitely a different look
YessirYeah, also wondering if anyone has done a complete light bar instead of individual pods? https://www.diodedynamics.com/ss10-sae-dot-yellow-led-light-bar-one.html
Just installed your harness last night, very nice, can't wait to start connecting stuff to it.if anyone is looking for a plug n play wire harness to work with my upfitter harness, i now have a few of these harnesses available again.
Plug N Play Harness for 2021+ F150 Lower Bumper Diode Dynamics Pods
Preorder: shipping late April If you have the lower bumper aux light bracket from SapceWhiteF150(AKA Connor Blai), this harness is for you! This harness provides easy plug and play connection of up to 5 Diode dynamics SS3 pods with Backlighting mounted in the lower bumper opening on the 2021+...cblightingdesigns.myshopify.com
These make wiring up 2,3, or 5 pod diode dynamics setups a breeze using Connor's Bracket.
It’s a really small trim on the ecos, the actual cutting should not take more than 10mins! For someone that is pretty handy I would estimate 3hrs on an eco and 1hr on a 5.0.
Yessir, those little tiny notches is all that needs to be trimmed.So, I have a 2025 402A Ecoboost 3.5L with the modular bumper and I am trying to develop a plan of attack.
I recently bought and received an Axis lower bumper bracket and a pair of Diode Dynamics SS3 pods. I have reviewed the documentation and posts in this thread, particularly the one I quoted above.
Question: Will it be less frustrating and easier for me to just remove the bumper from the truck as part of the install?
Hey @Cblaxx19. Thinking of pulling the trigger on 2 SS3s today with the 20% sale. I have your Upfitter harness and have the connectors that came with it to add new lights or accessories. Is the benefit of this sub harness kit to allow me wire two of them together and plug into one of the existing Upfitter harness connectors instead of needing to use 4 switches to accomplish what I could accomplish with 2?if anyone is looking for a plug n play wire harness to work with my upfitter harness, i now have a few of these harnesses available again.
Not exactly, Cory’s bumper harness just makes the setup fully plug and play.Hey @Cblaxx19. Thinking of pulling the trigger on 2 SS3s today with the 20% sale. I have your Upfitter harness and have the connectors that came with it to add new lights or accessories. Is the benefit of this sub harness kit to allow me wire two of them together and plug into one of the existing Upfitter harness connectors instead of needing to use 4 switches to accomplish what I could accomplish with 2?
This is correct. You’ll have to splice each lead from each pod together in order to utilize only 2 switches.Thanks, figured this out too after I went back to do some more research. It looks like the pods only come with a pigtail, so either need the harness (for plug and play) or some additional wiring to tie them together and get them into the engine bay. Then just connect the blue wire to one one of the connectors I have from the upfitter harness kit and the red to another with the black to ground on either connector and then plug into the upfitter harness I already have installed.
@SpaceWhiteF150 . Does the license plate bracket impact the beam on a setup like this? I would probably go SS3 SAE fogs on either side instead of the squadrons. I currently don't have the license plate bracket on, but want to keep that in mind in case I do ever get a ticket for it or decide not to risk it anymore.Dual squadron on a 25 Tremor!
