BigEasy’s Tremor build
What mount did you use for the rigid lights inserted in your bumper. I tried to do it but couldn't find any mount that work in that spot?
Great Truck ..
What mount did you use for the rigid lights?
This is a way to do exactly that!
Great Truck ..
Is there a rubber gasket between the flare and the paint to hopefully protect the paint from rubbing if you were to ever remove them
I
I got mine through ikon Motorsports web page. They also sell them on eBay so I would say they are the same ones
When you said you had to drill holes was it on the inner lip up underneath?
Can you provide a front facing pic of the flare to the front bumper? Want to see what kind of gap exists there.
Yeah they grew on me as well so here I am haha..
Yes, I had to drill 3 holes on the rear fender wells and 4 on the front. Then I used the original screws that Ford uses to hold on the little plastic trim pieces at the bottom of the fender wells.
The fitting and mounting was tedious, but with some general knowledge and hands on skills, wasn’t to bad. Could have used a second person to help hold and line everything up off the start but I managed on my own.
So I've got these on hand and after a dry fit the only issue I'm seeing is with the front attachment of the front flares. The lip does not go deep up enough on the front to capture the factory hardware. Curious how you remedied this? Thanks for your input.
