Fox 2.0 Coil Overs and Rear shocks
Do you have pics? Can you bolt mud flaps to them?
This is my current truck. But If i add flares to the tremor I'll likely color match them this time.
Yeah I’ll snap some photos. Black truck makes doing flares easy
No mud flaps have to go. I had all 4 and had to remove all to fit the flares.
Are these the Rough Country Sport flares? I like that they look OE and aren't exaggerated coverage...if I go with 0 offset wheels, I'd get a set....just leave them matte black to contrast my ABM Tremor.
They are. Let me know if you want install tips
Yes, Fox 2.0 threaded coil-overs will provide 1-2" of lift (need to select the correct coil-overs). Ride is fairly close to stock.
Do you sill like the ride of your fox shocks? I currently have falcons and looking for a better ride.
Yes, the Fox 2.0's ride quality is good. 40k or so miles on them - no issues.
Initially had HaloLift coil-overs - much harsher ride.
I wasn’t aware that Fox sold a tremor specific kit?
They have shocks that fit a Tremor, unsure why they don’t advertise it.
Off-Road Addiction (Blake) in OKC can provide the part #’s or sell the components to you.
If the Fox 2.0 kit is made for a standard f150 then it will fit a tremor, but you can only get 1” out of them safely without significantly changing your spring rate and compression.
I live in Edmond and have used Off-Road Addiction to install coilovers on my previous truck (Tacoma). I would definitely use them again. How much did the Fox Kit and installation cost you at Off-Road Addiction?
The eibach stage 2 and pro 2r kit are great for these trucks! If yall need one shoot me a pm!
Yeah, they are a good off-road store. Don't recall exactly: ~$1500 Fox 2.0's + install & alignment. It rides pretty close to stock, but with 2" lift.
