Leveling Kit
Here’s some more pics. The difference between front and back with 2” level measures out at about an inch an a half. Still trying to decide if I should stick with it or try to get the true level. Opinions gladly appreciated.
This looks really good!
Sorry, I meant 325/65/18’s…
Looks very NICE!. love your Tremor. I believe my next F150 will be a Tremor. I just compared Tremor pricing with Lightning and Tremor is about $15000 less expensive. just need to decide on color and order soon!
@TremorSC, new member here and like your setup. Would you mind sharing the height of your rig at the sat. antennas (probably the highest point)?
I'm looking to see how realistic it is to keep a leveled truck with 34.5"-35" tires in my garage.
Thanks for your help!
Yeah, I'm thinking it's going to be tight fit for me at factory height, and may need a little help from the garage door guys to squeeze her through. Tremor ain't bathing in the rain, baking in the sun, and battling the occasional hail, can tell you that.
Thanks for sharing!
What sort of clearance are you seeing between the tire and the upper control arm with the 325s?
I had the Readylift 2" spacer installed and it reduced the rake. Changed wheels, adder fender flares, and other cosmetic items.
That looks amazing!
Just out of curiosity does it fit in you garage height wise and do you have a standard 7ft garage?
Those tires are chonks! That should be about a 34.5X13? look up the best way to keep those beads from popping besides the obvious no potholes and hitting speed bumps at highway speeds.
All these trucks look killer with them levelled. For the life of me, I can’t get any shop to install one for me. They all keep telling me they are lift from factory, they don’t have kits that work, blah blah. Like what the heck!!
I added a pro comp 2.5" level to mine last week, see attached photo. Everything as far as sensors, ride, etc. seem to be the same as factory. So far so good! I want to add some 34" tires similiar to what another member posted on his silver tremor. Still doing some research on exact size i want to go with as i'd like to keep the factory wheels. I think they look nice for once!
Ball park......what was labor cost?
Has anybody taken a measurement from ground to top of cab with and without level kit? Leveling keep it from fitting in standard garage?
I didn’t do a before measurement but just checked and it’s 80” to the plastic antenna on the back of the roof which appears to be the highest point. That’s with the pro comp 2.5” level kit.
I did measure before I did the level kit and at closest point which is the black doohickeys above rear window are 4.5-5 inches below the standard 7 ft garage door…..mine still clears after 2.0 ready lift easily
