Jax_Tremor
- Aug 3, 2025
- 35
- 56
- Jacksonville,FL
- 2023 F-150 Tremor
Icon lift, 22’s on 35’s went on.. it’s done
In the house. Perfect.Painted and assembled. Just waiting on fog lights
I didn’t have the adaptive cruise so I can’t comment on that.Couple of questions for everyone who has done this.
1) Did you have to relocate the adaptive cruise control sensor?
2) Can this same thing be done using a 24 Tremor Modular Bumper (the center piece and the wings) or do you have to use a Raptor Modular center piece?
The problem is the bumper on the Raptor is different. The outer sections are wider due to the Raptor being 5" wider than a standard F-150. The 402a/402b modular bumper should be narrower.I didn’t have the adaptive cruise so I can’t comment on that.
You can definitely use the tremor bumper, when I did this project the bumper was not readily available but the raptor bumpers were all over eBay for pretty cheap.
The shorter outer wings are acquired separate and can be swapped on the modular bumpers. The center section is the same save for the color finishThe problem is the bumper on the Raptor is different. The outer sections are wider due to the Raptor being 5" wider than a standard F-150. The 402a/402b modular bumper should be narrower.
This looks so sick. What kind of fender flares are those?Icon lift, 22’s on 35’s went on.. it’s doneView attachment 43136
So just to update, this project is on a bit of a hold. Truck is in the shop for a rear end rebuild.
I’ve been chasing a vibration at highway speeds and when slowing down, I have been through a set of tires and 2 new rims (all under warranty) and none of it helped. So now the dealer wants to replace the rear ring and pinion as they said the backlash is out and coast side of the gears are not meshing properly.
Plus at the end of the month I am moving back down to Florida to take a job running a new upfit department for a Ford Dealer.
As soon as I can get a free day to work on it, I will post up.
Appreciate everyone’s patience……I know a lot of you are waiting to see how well this fits.
WhoaThanks to @CrankCase I was able to install the modular bumper to finish off my E Tremor build. I used @Jax_Tremor paint colors for inspiration. We happen to have the same flares as well. Prior to this I Tremor swapped the interior, aux lights, and skid plate.View attachment 45356View attachment 45357View attachment 45358View attachment 45359
Where did you get the camo print tremor seats?Thanks to @CrankCase I was able to install the modular bumper to finish off my E Tremor build. I used @Jax_Tremor paint colors for inspiration. We happen to have the same flares as well. Prior to this I Tremor swapped the interior, aux switches, and skid plate.View attachment 45356View attachment 45357View attachment 45358View attachment 45359
Thanks! No screen swap, my truck started off as a pro. The pro and xlt trims come with the 12 inch screen. I like this set up better. You loose the physical climate/radio buttons on the bigger screen. I actually swapped my climate control unit out for the one with temp displays from a 2021 gas truck. Getting the upfitter switches working was crazy, I had to figure out how to connect the upfitter fuse box and make my own harness to the switches.did you do the screen too? i thought the lightnings were more portrait orientation. thats dope as hell
me too...wifes expedition has touch control everything drives me nuts. you're just rockin all the fun bits hah!Thanks! No screen swap, my truck started off as a pro. The pro and xlt trims come with the 12 inch screen. I like this set up better. You loose the physical climate/radio buttons on the bigger screen. I actually swapped my climate control unit out for the one with temp displays from a 2021 gas truck. Getting the upfitter switches working was crazy, I had to figure out how to connect the upfitter fuse box and make my own harness to the switches.
Thanks man, I'm glad you guys dig the truck. I'm installing a M&R 40 inch bumper light bar this week. Then suspension down the road, right now I just have a 2 inch level.me too...wifes expedition has touch control everything drives me nuts. you're just rockin all the fun bits hah!
