onboard air
Didn't even think of that. Is there a popular chain of offroad shops that's reputable? I think 4wheelparts Is one? Again, I'm in Miami, it's scam central here.
I would recommend it. They may recommend placing it under the hood like @metprevious truck because of the size of the wire needed to support 50A over that distance. I'm mounting mine in the bed but have a separate battery i built to power it.
Didn't think of that either. I read the single highest peak pull is 38A, so I'd hook it to a 40A switch. 8ga wire I read. I'll ask them. I'd really like to have it in the bed.
4wheelparts is pretty popular. My experience varies on the individual locations - some guys are great and knowledgeable, others not so much. Ask around of some people you trust for a recommendation.
I would also encourage you to think about learning to do it yourself. Wiring is not rocket science. You will get to know your truck better, learn a skill you can then use when you go to put lights and other accessories on, and be able to diagnose it better when something goes wrong. Your wiring kit probably came with a relay (right?) and I would suggest using it. It's not that hard - just go slow and be thorough.
I'm inclined to do it, but I'm also very short of time. It would take me likely 5 times as long plus troubleshooting, and I just don't have the time for that. Someone knowledgeable will do it in a couple of hours. I'm considering asking them to do the dash cam also, I assume they would do that if they do a compressor. Again, just to save time.
I'm a construction PM for a 9 figure project and I run a GC business on the side, I would love to tinker more but I'm just spread too thin. 🤷‍♂️
Also going to drive an extra 40 miles to the better reviewed one, just to be safe. One has a 3.6 in Miami and the west palm beach one is 4.3
I used 4ga on my previous trucks (I also over-engineer everything) and will do the same when I connect both batteries. I'm trying to figure out the wiring harness and a common ground, currently.
Frame rail at the top would be about the best ground I would imagine.
Made the appointment with 4wheelparts for the compressor and dashcam. He was unsure about the dash cam but said bring it and they could probably figure it out. I'm sure they can. Let you guys know how it goes.
I wonder if you could hook it up to power from the generator, if so then you could mount it right there on the built rite racks and just run the wire there? Just a thought.
The pro power does open up a lot more options for onboard air! If you could hard wire a 120v compressor in and have the on off switch relay hooked to an upfitter that would be awesome.
Most of these 12v units. Your talking about hooking it to the 120v outlets?
I've been thinking about what I want to do. I haven't bought anything yet. I'd buy a little 120v thing as a temp solution if I found one that was good. Not that I've looked super hard either.
If I get a ARB 12v thing I'm leaning back towards mounting it in the engine bay and trying to run an air line that can be reached without opening the hood.
I realize that most are 12 volt, but I also have seen conversions done on some with success, not an electrician, but may talk to a buddy just to get his take on it. There are a couple of decent 120v portable compressors on the market, not quite as much cfm as an arb but close, I may chose that route and just mount it right at the generator plug in. If I do I'll post more info.
Really, run the bed to the 12V feed for the inverter in the back seat. It's an isolated alternator
I don't mess with electricity unless I have a direction diagram, so it would be something I would have to get help with to do something of that nature, as for hooking it up with a diagram how it's supposed to be done that I can do. I'm shy when dealing with electricity because I got knocked through a wall once because the line ran straight through and not to the breaker box. I've hated electricity ever since, we had the main breaker off and their should have been no power at all. I tasted my fillings for a month.
I'm in the same boat. Working in construction I've seen some shit, and I know the potential Danger behind it too much - I prefer not to mess with anything above low voltage wiring.
I've been debating what I want to do for air as well. Main use will be to air the truck's tires back up after a trail or for misc things while out camping (bike tires, mattress, water inflatables/toys, etc.)
Was originally going to go for a mounted option like ARB, etc but then I got to thinking... I have the 2kw Pro Power and it would seem smart(er) to use some type of compact air compressor via an extension cord. I wouldn't have to deal with long air hoses, mounting, and it could serve different needs with one piece of equipment. Added benefit of course is with the extension cord (that is always in the truck) I have a lot more flexibility in where and how I use the compressor, when I am done with it goes back into the Decked drawers.
Anyone already done or have thoughts / recommendations?
I will share some that I have come across in a little while, I have been contemplating doing the exact same thing, the only issue is the time it takes to inflate a tire back up. Most of the ones I've looked at are smaller so as not to take up a lot of space.
There are more than this these are just the ones I have considered.
That TCBL looks interesting, nice and compact. Not a lot of (English) reviews on the web or YouTube and the Amazon reviews are mixed (seems overheating is an issue?)
After some browsing, a little surprised at the lack of products available/made.
Yes the tcbl does look interesting, any constant on air compressor is going to get hot, that's why most compressors have a tank with them so that the compressor can have a minute to cool down. Even the ARB compressor gets hot when ran continuously.
Reactions: E54
