Quick-Disconnecting Sway Bar / End Links ?
These are sold as a pair (2 Links). I am unfamiliar with these tremors as far as how the sway bar rotates and may contact anything. That is very dependent per vehicle. On our 3rd gen 4runner, if you have good sway bar bushings, the bar stays up and out of the way completely. front and rear. On some newer 4runner models, you do have to tie up the sway bar to the frame or shock mount. We also have a universal frame mount that was developed for Tacoma's that may work for the front bars.
We recommend only disconnect one bar if it is a contact issue. As you state perfectly, you really only need one link off to be disconnected.
Right on.
Thanks again for participating and being willing to help. I have no issue giving you my money if you can solve this problem.
I think in the interest of accessibility, one end-link is enough to disconnect.
They make very little noise. Depending on the style, we use some rubber isolators to eliminate rattles. I get that concern a lot with heim joints. I don't know what kind of joints everyone is using, but we use 3 piece FK Bearing heims. No servicing needed and no noise. I've been running them one my own 4Runner for years.
If anyone's interested, shoot us a message on the web.
You were looking for measurements. If you can give me the exact measurements you need I've got my in the shop on a lift and I can get them.
Did anyone get a set? I was asked for measurements and totally forgot to grab them!
Not yet but I did get a measurement of 9 5/8". Back of bolt head to end of bolt head 3 1/4". Stud length 1 7/16".
Hey guys! Sorry we got crazy busy leading up to SEMA this year. I'm caught up now and had to log back into here. 100% honest I hate forums and totally checked out of here. But I'm back and were here to help you guys. I looked up our last order we had for a tremor and this is what he sent:
"Yes I received them! I just finished installing them and this set up with the shorter bars was definitely the correct way to go. I would not recommend running one side disconnected, thereโ€™s not enough room in there to articulate safely, both side need to be disconnected together and the sway bar tied up out of the way. If you wanted to add this combo to your site, this setup would fit a 2023 f150 tremor with a 0-3 inch strut lift, or a 4 inch lift via drop bracket, taller than that might need a shorter bar unless using a knuckle that has a sway bar end link relocation.
Thank you
Dustin"
So for that same kit, That would be our Type 4 Links 8.5-9.75 W/ 12mm Disconnects.
Hope this help[s you guys! Feel free to Replay here or message me!
[email protected]
Text/Call 805-395-9450
This is funny, I just installed a rear sway bar because I had enough of the sketchy body roll. I used jeep quick disconnects.
