Tremor front suspension vs regular F150
Yes I do have them. Hopefully this is what measurement you were speaking of. 7 3/4” is what I get as shown. If not I can get another of something else.
Dang. I really thought that's where For would have put the extra length to make the Tremor struts 23", but that's the same as Tremor, not shorter. Lariat struts overall length is 22", bar to mounting surface?
I will check that and reply tomorrow, I recall the overall length very minimal when they were side by side. Spring rate I think is what makes the difference upon the trucks weight being forced downward.
As for that overall length, depending on which side I measured, I came up with approx 22 3/4". It appears to me they are very close as I mentioned when I had them side by side prior to swapping, it didnt appear much difference at all, until they were installed, hence my mention of a heavier spring rate to compensate for sag (3/4" gain in height) and what I experienced was less of a "body roll" when in turns and when driving over surfaces that made the Lariat springs/struts bounce more and lean/body roll in turns.
Coming from the Lariat, this was a very cheap and minor upgrade in between going to a full swap. I have yet to ride in a truck with the Fox/Rausch or whatever else guys are using. I am content for now, although the rear shocks that I used also from a Tremor, seem to be very close to that was in prior. The slight difference I feel is likely the upsize in tires.
Ok big question. Are the stock front spring progressive or liner?
I've had a couple FX4's and my Tremor has softer suspension for sure. Whether because of the tires (all my FX4's had 20" wheels) or different shocks / springs / etc. I'm not sure. I would be interested in anyone replacing their rear shocks for better ones and keeping the same rake as OEM.
All the writeups on the Tremor indicate that the factory lift is achieved via different knuckle, UCA and springs from the regular F150. Has anyone seen a side by side comparison where someone has taken these components off both trucks and laid them out side by side to actually document and measure the differences? I would love to see this, and what part numbers are stamped on each. Maybe even an exploded parts diagram of different trucks would show something?
If I go to any of the oem Ford parts sites and select a '21 XLT or a '21 Tremor and then search for the knuckle they come up as the same part number.
So it looks like Tremor has is own specific knuckles. But the parts search shows the same number for the upper control arms. There're actually several knuckles- 2wd, 4wd, BEV (battery electric vehicle?), performance, tremor, etc.
