The top and middle pic look good to me, is the bottom pic in the same position as the top two pics?
Yeah, all the same placement.
Here is it further back for comparison.
I think someone else already said it, but for what you have going on it works. It's not for me, but it works with your whole set up. Happy wife, happy life. Right?
I got it, its very similar to the Raptor R however the R has this decal in front that I feel brings it all together instead of the one center vent being so far back. If you could add a black center decal that matches with your side hood decals with the center vent I thing that would complete the look!
Installed a BAK X4s tonneau cover and Builtright molle panels. Did have to cut off a couple squares in the upper corner of the two small panels to fit better around the clamps holding down the cover.
Thanks for posting, @Charky. Builtright panels are definitely on the short list, but have gone back and forth on whether I'd mess with the two smaller forward panels. I have the MX4, and would likely run into same issue.
Maybe, might be too much vinyl for me though. I'm not sure I'm a fan of stick on vents is the underlying issue lol.
I may just put it on and see if I can stand it, if not take it off; Oh well. Thanks for the input everyone.
Added my orange front stripe light, added baja design flush mounted lights in the rear, added bilstein 5100 level with matching rears. Gained 2-2.5", leaving me with 2" of rack, Method rims (1st truck to have these ever), and 285x75x17 wildpeak at3w's.
The smaller, front panels are needed if you want to mount longer items like shovels or a hi-lift jack. Other than that, it's just another place to hang stuff, you'll be surprised how quickly you'll use up the space.
Cutting the panels was quick and easy, but I had a sawzall and metal cutting blade.
Reactions: ETN
I may order the larger panels at first and see how it goes, doesn't look like they shave a ton of money off for buying the full set versus a la carte. Have no doubt they will fill up fast - I want to get a bunch of stuff out from under the back seats. But yeah, I'm sure I'd take the corners off the small panels with a grinder if needed. Sold the hi-lift when I got rid of my hilux, may get another one at some point!
It is growing on me, it looks perfect. Where did you get the black hood decals and "ford performance" from?
Unfortunately, both parties have been told by ford to stop making them. But you can still find the stripes on other etsy shops and I'm sure if you search "ford performance decal" it will have a result that works.
Allowed the ford upgrade and now have a pretty 400a
Added my orange front stripe light, added baja design flush mounted lights in the rear, added bilstein 5100 level with matching rears. Gained 2-2.5", leaving me with 2" of rack, Method rims (1st truck to have these ever), and 285x75x17 wildpeak at3w's.View attachment 16718
where did you get that mountain decal? I would love one of those.
How hard is it, or can someone post how to adjust the fog lights? Mine are also pointing straight at the ground it seems
