‘24 Orange Square Tow Hooks
Used the heavier/forged/squared off ones, didn't want to give up any clearance on the top side, preferred to gain some. Installed mine using upgraded/longer bolts with a tow hook spacer kit. Gained back what is lost doing the swap and a bit more. Easier to use with shackles, hard or soft, etc.
No trim piece used; what area there is around the hooks is another access point to wash off the gathered debris on the front skid plate.
I did the beef and cheddar special at lunch today. Didn't have to drop the whole pan just loosen the 2 rears and drop the 4 front bolts. Thinkin I might cut the plastic covers and put them in though...don't know if I like having those bolts/the frame rail open like that with all the wet we get here.
Spring arrived here in R.I. close to 60 degrees which means the start of Mod Season! I am extremely happy to report that that HEAVY DUTY TREMOR Orange tow hooks do fit my 23' Tremor no "MOD" bumper needed! Tips on install, when taking off stock tow hooks take off front bolt ONLY and loosen the rear bolt but DO NOT TAKE OFF rear bolt otherwise your 45 minute job might turn into a few hours. (if you did and lost the nut end in the frame you will most like be dismantling some or all of the bumper). These hooks fit AWESOME and I was second guessing if I wanted to put the rubber molding back on as they fill up the space very nicely!. I did install the rubber molding but you have to definitely trim. (see pics shows front view and rear view of what was trimmed) and the fit great! Well hope this helps those waiting to def find out, but yes worth every penny. The difference in hooks is actually comical, as the stock ones seem like an old ring tab can opener to a PBR🍺. Have about 9 more mods to do from my winter purchases, Raptor take off wheels next and Fox SVT rear shocks.
Thank you for this! I have a 2021 and those weak loops have got to go! I love the square hook look. Nice Job!!!
Yeah, but those covers, especially if trimmed...may trap more corrosion causing moisture mud/crap vs leaving them off allows crap to drip off and air dry better.
Hi guys,
I just bought a 401A Tremor (2025) and want to put the square tow hooks on. From what I have read in this thread is they only fit the modular bumper but then I found this video below and it looks like he has the 401A. Has anybody in this forum tried to put them on a 401A? I dont want to order them if they don't fit and get hit with high shipping fees. Thanks!
Hi guys,
Yep, you too shall have the beefiness!
Post in thread '‘24 Orange Square Tow Hooks'
https://www.f150tremor.com/threads/‘24-orange-square-tow-hooks.4597/post-71063
