AM Offroad Grille Lights
Their email to me said you can pay the 130+70 shipping from china, or when they are in stock they will be $190 with “free shipping” 🤣
It’s bullshit
Wow at least they explained it more to you. What got was a bunch of garbled English that clued me into the real situation.
I guess I don’t have much to complain about right now. My truck is still in the shop getting repaired. Hopefully I will have it by end of week.
OEM is better.
OEM is better.
Those do look nice, I'm not seeing those for my year (2025) when I filter to lights, do you happen to have a link or more detail on them?
I’m not even sure if Ford Accessories will make them available to install on other F150’s since they’re part of the LOBO package which is an STX only option.
More than likely one would also need the STX grill.
Here’s a video and a better look.
guess I lucked out. They have the connector is stock just received my set today and finished installing not to long ago. Satisfied with the lights, harness and connectors.
  • IMG_4064.mp4
    3.4 MB
  • IMG_4062.mp4
    3.3 MB
Awesome those look great! Definitely happy to see they have the connector now.
My harness is supposed to be on the way. Will report back once received and installed successfully.
Recieved the headlight harness and wiring. Got it installed over the weekend. It worked well and functions as expected. I could not find an easy way on my 2025 to take the wiring down into the bumper like Fifty Nation showed. There seemed to be a solid plastic plate in the way. I did discover that there are square holes on each side of the grille, parallel with the heights that is about 3/4 of an inch. It's a struggle but you can get the wiring and the 3pin connectors through those holes. Hopefully that's helpful for anyone else getting the harness. I am not sure if 2024 is the same and has the same holes.
Nice! Would love to see pictures of video of the different functions when you have them! Would definitely love to see what they look at night from a reasonable distance away. Still on the fence about this vs. raptor lights, vs. nothing!
dont. put. raptor. stuff. on. a. non-raptor.
2 weeks into Winter and a strange behavior with the DRL and the AMOffroad grille light. Suddenly when locking the driver side DRL flashes, then The passenger flashes and the passenger stays on for some time after leaving the truck. AM support dismissed right away even though their Y cable headlight harnesses are at play here. I will have to reconnect the factory harness to the headlights to see if it persists before pushing back. Here is a video
Hey there not sure if this string is even still active. I was curious Woodsy15 what happened with your light issue. Mine is currently at the dealer as neither of the high beams will activate. I know they did after installing the AMoffroad grille lights, but then, just seemed to stop. I'm not even sure it's related as I do have the plug and play harness. I did have the same issue as you with the one odd market lamp and then both staying on for some time.
This will be interesting.
Looking forward to reading what your dealer says.
Y'all seen "Night Rider," wouldn't it be cool if the lights went back and forth like "Kit"?
So the American Modified plug and play harness is apparently NOT water tight. The ford plugs coming off of the lights got corroded to the point where they shut off my high beams - permanently, and then I'm thinking for some reason messed with the plug enough that the marker lamps in between the high and low beams would stay on for 15 mins or so after the truck was off. My dealer, rightly so I guess, did not cover this under warranty, but did get the issue fixed by installing new plugs on the headlights and connecting as done from the factory. The AM Grille lights are still installed, but not connected to anything. I suppose shame on me for not applying dielectric grease at the get go, but the OEM connections didn't have it so i figured it should be good. Now on to fight with AM to see if i can get any sort of warranty out of them.
EDIT: Never mind. Seeing now someone is already doing this.
Is anyone running these as just grill marker lights and not sequential turn signals? The sequential seems cool and all but with the issues people seem to be having, I'd love to just wire them into the DRL's or maybe even just an upfitter switch?
