Cobb Radiator Shroud and Scoop with Bracket
Just need to confirm , has anyone installed the COBB radiator shroud fit a 2023 Tremor? I called COBB today, they stated that it was tested on a 2022 Tremor but have no yet installed on 2023. They stated it is the same generation and should fit. I ordered today, along with the bracket and coolant cover. We will see....
No, but unfortunately now I may have to, that looks clean with the coolant cover (which I do have and is great quality). I'm sorry, but you and my wallet can not speak to each other again.
I like the look. I'l probably get it if I can get on the grill lights list and do all in one shot.
The scoop seems bigger than stock don’t you think? It looks good for sure. Did not want to buy aftermarket intake but wanted
Something that looked good when I popped the hood and I’m sure there is a tune in my near future. Did not get shroud once I found out I had the “better” factory one in their vid 🤷
The scoop does seem bigger than stock. Ya I know what you mean on the shrouds. Not sure which is best between the updated Ford and the COBB? Both are better than the previous version. Not sure when Ford made the change. That COBB shroud should fit the 2023 but 100% sure. Again, if Ford upgraded the shroud in 2023, not sure if you would still feel strongly about getting the COBB version. I think that COBB intake scoop bracket for $20 makes sense. I'm not sure exactly what causes it but I noticed mine was curved and bent up in that area where that bracket would go.
@808 Tremor TY! Well I ordered will let everyone know how it worked out. Do like the look of the Cobb Shroud.
Just ordered the shroud and intake scoop bracket. Looking back at the photos of the coolant res. cover I installed in December, I found that my MY22 has the updated OEM shroud on it.
Well I’m pretty sure my 2021 has the old one, I was going to do the zip tie fix but if your look to get rid of your updated shroud I may be interested!
I was going to wait, but I just ordered both as well. Gotta stop reading this forum. :D
I’ll let you know when my new one gets in!
Has anyone installed the scoop into an aftermarket intake? Does it match the stock locations? Would love to add this to my roush intake
I have not installed it, but it says it works with the stock I take. So, based on their info, if the stock scoop works with yours, it will too.
Mine is coming in Friday. I'll probably install then. I have a stock intake and will add that drop in COBB air Filter. I will post after with pics. I don't know how the Roush intake is but maybe the pics will help.
Doesn’t look likes it works for 5.0s. I might have to sadly pass.
Had time to install the COBB shroud, Air scoop and the drop in Air Filter. Overall pretty easy and quick. COBB products are well made and fitment in really good. The bracket for the Air scoop gave me a little fit. Trying to line up that one screw on the left side. Overall happy with the products. Didn't get a chance to really test out yet but hoping for a little improvement with the Livernois Tune. the OEM stock shroud is really flimsy. I am not sure if that effects anything or it is a bad thing but I can see what COBB was thinking after installing all these products. The air scoop inlet is wider on the COBB but the height is the same at 2-1/8" ish. OEM is about 9-1/2" and the COBB an inch more at 10-1/2" width. The COBB is a little thicker at the curve towards the back. I attached photos for all that were interested, and I know were curious to see if the Air Scoop would work with other brands like Roush.
Great summary on the Cobb products! Now I may have to order the the air scoop in addition to the shroud, bracket and coolant cover i ordered.
I got the shroud yesterday and the bracket arrived today. Coolant cover is still on backorder.
