ksheldon63
Installed mine today also and fit great except for that left bracket hole like you said. That bracket bends super easy and installing it is tight so it loses its shape a little.Had time to install the COBB shroud, Air scoop and the drop in Air Filter. Overall pretty easy and quick. COBB products are well made and fitment in really good. The bracket for the Air scoop gave me a little fit. Trying to line up that one screw on the left side. Overall happy with the products. Didn't get a chance to really test out yet but hoping for a little improvement with the Livernois Tune. the OEM stock shroud is really flimsy. I am not sure if that effects anything or it is a bad thing but I can see what COBB was thinking after installing all these products. The air scoop inlet is wider on the COBB but the height is the same at 2-1/8" ish. OEM is about 9-1/2" and the COBB an inch more at 10-1/2" width. The COBB is a little thicker at the curve towards the back. I attached photos for all that were interested, and I know were curious to see if the Air Scoop would work with other brands like Roush.
Where did you get those 4 top front Phillips head plastic plugs like they have in their picture? I just have the solid push in OEM plugs.
