GHawk16
- Oct 19, 2023
- 102
- 50
- Denver, CO
- 2023 Stone Gray 401a 3.5EB
Appreciate the update. i think the best roads to test these on would be forestry roads as they have the small holes and are typically washboarded in areas. I can go on some of the country dirt roads somewhat near my house and test them once I get mine. Seems like they turned them around pretty quick for you which is great. Did they set yours at 2.5" ride height? Be nice to see a pic of what they set your collars at for comparison so when I get mine I can compare.I received my replacement shocks from Elka yesterday and I learned a few different things that I was wrong on prior. the first number on the spring "11.3 x 408" is going to be Kg per MM and the second number is the length of the spring in MM. So I did call Elka once they arrived since I have to pay to install them again to make sure that they are the correct ones. The new ones have a different valving curve to where they are set up to run with the high speed set at full open for the road. Since the springs are #550 instead of a #700 I was told that there is more of an adjustment on the stiffer side of the HSC to give better bottom out control off road. We will see how this set up works. Since leaving Utah for Tennessee the most off roading I get to do now are driving the forestry roads. I will let you guy know the outcome and difference in ride quality. I know Fox uses #550 in there pro race 2.5 coilovers so I am thinking that these may be close.
