Leveling Kit
Absolutely! I’m actually kind of nervous only because I can’t find anyone with a tremor online running this set up in the front. Just kind of trusting the installer .
Are you talking about the snap rings? I’ve been running them for 2 months/2500 miles.
Yup these ones below. What do you think? And what setting did you put them at? And any pics? Lol
I have them set at one notch below the top one. Came out to 2”. Had them at 2.5” or top notch but I felt the CV angles were too high. I posted a few times about them on here.
Looks great. Mine is white too so this gives me a good idea.
So I think you have yours on the 4th notch. Which makes sense for around 2 inches. I think I’ll do the same! Is this photo with the 1 notch below the top?
Perfect. Yea based on that pic of the side shot, the next notch up would def be too much for me. It looks to be sitting perfectly, anymore I’d worry about being nose high when towing.
One notch higher is almost level. I went one down because cv angles and towing.
Yea I tow also and don’t want wonky angles. However, this stock rake is absurd. Im hoping the same notch you used with the stock tires looks much improved because I don’t want to have to use the highest setting.
Here’s one parked downhill to give you an idea of the max rake you’ll see at that notch
Yea still looks great to me! I was walking out to my truck yesterday. It was in a parking lot flat. The rake was so insane it looked like a hot rod, I couldn’t even look at it lol, looked so ridiculous.
What rears are you doing?
The ford fox performance 2.0 is a fully built coilover ready to install. These are just the strut that fox provides but you use the top hat and spring from your factory setup.
So is anyone using these? If I understand correctly these are meant for the previous generation: on the phone with fox today, for the tremor the gentleman I spoke with recommended this gen, given that the spring rate is heavier. It would likely provide more lift for us.
Anyone running these who could provide some input would be great. Especially as to ride height and ride quality. Thanks in advance!
I am running these in the front. Put them on the second to last setting. Rides amazing still. Others on here are running them on all 4.
