New ICON F150 3inch Suspension
I have the Icon leaf springs installed. h\They did remove the rear blocks. The installed told me they were not needed and that the rear is all on springs now. WHat did you do
The blocks are still there but the ubolts aren't threaded all the way, they aren't long enough. I was thinking to remove them and add the rear extra leaf to raise it back up.
Did you install the extra leafs? I have it without the extra one now.
I had the stage 4 with leaf springs installed. I had option 2 of the stage 4 system They left out one spring. SO it is moiré that the OEM. It does nit sag with weight at all.
Do you have the 1" lowering shackle installed?
Yes, the invoice said something about a lowering shackle, so yes I do have that. This really confused me because the shop said the kit would lift my truck a bit. I saw the lowering shackle and I was confused. The finished truck is lifted over OEM, but it now does have the lowering shackle.
It's because the curvature of the leafs is much more than stock and that's where the lift comes from.
You’re not kidding - these have fewer leafs and far more curvature than other HD options. I configured mine in ‘option 3’ but still have the oem shackle. The leafpack contacts the exhaust at full droop, which a shorter shackle would mitigate.
Curious to hear from anyone with the CDCV shocks and coilovers, what settings do you use and prefer on road . I understand this is very much personal preference too, but curious what people have landed on. Finally got some time in shop with my friend to get ours installed and been playing with the settings on each extreme, just to get a sense of the difference.
Seems off road makes sense to have soft and hauling/towing makes sense firm, but on road regular unloaded driving is likely where the range of settings differs.
5, makes it simple and honestly drives good in the city environment where the roads aren't great. Still firm enough though. Rear sway bar helps.
I could have it at 6 or 7, but 5 let's me just go over speed bumps at 20-25 😂
Does anyone think the coilovers will need to be swapped out for ride quality/ lift height with an offroad front bumper installed? I am curious if the additional weight of the bumper or winch will be an issue.
Winch yes that's a lot of extra weight on the very front, bumper not really unless it's super heavy.
In one of the rare times I [partially] disagree with you... Our front bumpers are light (I don't think they're 120 pounds) the last time I replaced a front bumper it was closer to 200. Add another 20 pounds for the winch plates and 70-110 for a winch (depending on steel vs synthetic rope). Generically you're adding another 150 pounds in front of the wheels. So for a light spring if 600 pounds that's 1/8 to 1/4 inch more compression and the ride attitude will depend on if you have significant weight in the bed. I.e your rake with be more with less weight over the rear axle. It's a similar concept to how a wfh works but in reverse.
3. I look for potholes to intentionally drive over.
Stock, at least the springs. Elka or icon, less likely but maybe a 50 pound heavier spring if it's too bouncy.
All that to say im home and just had my Icons installed. With the swarfworks hidden winch, winch and big Cobb intercooler, it is sitting right at 1 7/8 lift up front. I love the difference in the rear springs over both my custom and oem.
Hey that's why we're here if the bumper is that light then yes I totally agree, like I said if it's heavy but if there is that much difference between the factory and aftermarket bumpers you would definitely need to have a heavier spring rate or at least one that will compensate by being longer like the Eibach's that add 2.7" on normal truck.
Glad your liking your new setup
Yeah, I took it up the rough side of my back yard. Other than needing to replace my now damaged steps with sliders, it did really well. I may end up going with a different shock in the back (the bilsteins were a bit slow) and needing to finx my headlights, it's doing really well. Just in time for an October trip to Alaska.
I usually drive around at 4 both front and rear. When towing my camper I set the rears to 9 which helps improve the rear end getting pushed around (or so it seems at least)
I'm waiting on a good sale for the Icon or the Halo kit. Regarding the tubular Icon UCA, is there a bracket for the headlight for it? I see the 611071 part number from Icon but its for the Billet UCA not the tubular.
I'm waiting on a good sale for the Icon or the Halo kit. Regarding the tubular Icon UCA, is there a bracket for the headlight for it? I see the 611071 part number from Icon but it’s for the Billet UCA not the tubular.
The tubular upper control arms do not have a provision for the dynamic bending feature.
Ok, sort of answered my own question but can anyone confirm this?
