Oxford White F150 Tremor Photo Thread
This is better
Found a friend at lunch. First white one I've seen other than mine. I've only seen a black one and a blue one here in Miami. Mine is on the right. You can tell the rake difference.
I was one the lucky fifty whom got the Tremor Amber Grill lights. Bought these before I bought the truck and finally had the time to install them.
Just picked up my Storm Trooper. Have added a tonneau cover, rear wheel liners, and tinted the front windows. About to mount radar detector from rear view mirror.
Congrats and welcome 🍻
Finally got side vent lights done. First set were defective. Gotta give F150leds some kudos they replaced them right away free of charge.
Ok, so here is the old gal. 2022 402a Tremor
Spray in box liner
Back Flip Tonneau Cover
Custom off set splash guards
Decals to spice things up a bit
Tux Mats (so Awesome)
Next up will be 2" level, and either factory rims with a much more aggressive tire, or 20" Fuels. Still browsing some lower profile raptor flares.
Electronic
I stream to monitor (awesome)
Forscan
Enable all Cameras at Speed (4 in my case)
Auto Start/Stop Disabled
Double Horn Honk disable
Fogs on when high beams are on (aka Bambi Mode)
Enable digital temps for engine & transmission on 12" digital cluster only
Disable driver & passenger seatbelt minder
Disable Auto Engine Idle Shutdown of 30 mins
Prevent headlamp switch from defaulting to Auto position
Disables door ajar chime
Disable key-in ignition chime
Mirrors - Lincoln Autofold
DRLs - full brightness
DRLs - include parking lights
DRLs - allow fog lights
Disable Fake Engine Noise
Enable 75th Anniversary Splash Screen
Enable Unreal Sync Theme
Enable Cimate Bar at the bottom of Sync screen
Enable Heated Steering Wheel on climate bar above
Enable Cooled and/or Heated seats to climate bar above
Enable Lightning F150 Splash Screen
Enable Oil Life in Sync Settings, Vehicle
Glare Free Menu (replaces Auto High Beam in APIM)
Front Camera activation when sensors go off (best one yet)
B&O Unleashed wherever that is.
Still working on the walk away locking and chirp
Gently poking around the rest of the modules.
Spray in box liner
Electronic
Forscan
Do you mind sharing the code for the 75th anniversary splash screen? i didnt see it in the forscan common list or apim...
Thought I blow the dust off our dormant oxford white Thread. I don’t see a lot Tremors when I’m out and about but saw one today. I think these trucks look sweet in Oxford…. I’ll be upgrading tires here soon just ordered some 295/70R18 on Saturday.
Spray in box liner
Electronic
Forscan
I am just getting my leveling kit together for 35” tires and new rims.
Hoping the matte bronze makes the trim pop a little more.
Like your truck, looks leveled. What did you use?
