Octavio2
Bumper was damaged and parts are on back order so just decided to go with a ADD rear bumper. Had to cut the bottom plate to allow the clearance for the exhaust. I think it came out pretty good.
Can you show a pic of what you mean by "Had to cut the bottom plate..."? Thanks.Bumper was damaged and parts are on back order so just decided to go with a ADD rear bumper. Had to cut the bottom plate to allow the clearance for the exhaust. I think it came out pretty good.
Yeah so the bumper is designed for the side exhaust. I had to cut the plate to allow the dual exhaust to fit properly.Can you show a pic of what you mean by "Had to cut the bottom plate..."? Thanks.
What license plate relocation kit did you use? I had the mishimoto one but it was a little high and kept triggering the sensors.Finally got my 20" bar mounted in front of the inter cooler, holy smokes what a total pain in the ass.
Mount needed modification, entire bumper basically needs to be pulled apart as you can't just remove bolts like normal F150's, ours have a harness thing.
Anyhow, I recommend paying the dealer for a couple hours because if you move that lidar deal any amount they have to recalibrate anyhow.
How are you liking your setup? I'm getting back to work on mounting my 50" to the super pacific and trying to figure out a wind deflector solution for it. I need to find mounts long enough to prevent whistling but something that the mounting holes to the camper are inboard, slightly. That and trying to figure out a way to mount a wind deflector along with it.Finally got my 20" bar mounted in front of the inter cooler, holy smokes what a total pain in the ass.
Glad to hear it! Also, thanks again. I am going to order the honey badger, can't wait to install it. This was honestly the deciding factor between the honey badger and the Vengence bumper from fabfours, since it had a built-in bracket location.Yes, I used their relocation kit and it's working great.
I use the adaptive cruise control often, but have to drive a while to get to a blue cruise road....but that blue cruise light mode where i put a 2# weight on the wheel still works fine on local roads.
I like the honey badger bumper they have as well.
For sure I got first rate service from ADD, an intercooler got damaged in transport and they sent a new one asap, didn't question a thing, exactly as I'd expect from a first rate place.
My installer was running into issues due to his inexperience and their tech support was super helpful and available right away. He was steered correct several times and I appreciate their support.
What mount you used for the lightbar?Finally got my 20" bar mounted in front of the inter cooler, holy smokes what a total pain in the ass.
Very cool, just need to bump your front and get the ADD replacement!Bumper was damaged and parts are on back order so just decided to go with a ADD rear bumper. Had to cut the bottom plate to allow the clearance for the exhaust. I think it came out pretty good.
Thanks for posting.THIS dashcam is amazing, first of all the installation is smooth and requires nothing.
It fits perfectly on my 2021 402A, bluecruise and assisted cruise control confirmed working great.
It comes with the wire to plug into our rear mirrors and nests nicely behind the rear view.
It's just barely visible when driving.
300 per wheel to swap tires? WtfNo way am I paying 300+ per rim for mounting my winter studded tires on cool rims.
Got this older set of rims for cheap, don't like the silver but the rims are likely to get screwed up by chains anyhow, so it is what it is.
View attachment 1614View attachment 1615
It will look much cooler in the spring with the original rims and these black lug nuts.
