KPv8Tremor
Just installed my grille lights- super pleased with how they turned out. Although it did take us much longer than expected to install. My dad damaging one of the light bars black ground pins connectors didn’t help as we had to play around with the soldering gun to get it fixed. Took us multiple attempts to get it right. I echo everyone’s statements about widening the hole to drill in grille to help with clean wire install (it’s a bit tough) as if you don’t widen up the added hole a bit it can make the led light bars push inward and not be flush. We widened the hole slightly over and over as we struggled to get the wire to sit right and through the additional hole. So that added a lot of time as well. To those who have yet to install. Remove the battery and battery tray so you if you plan to connect to an auxiliary switch. It’ll give you much more room and only takes a 5 mins or so to remove those. Follow his instructions and watch the videos. And have a dad that can show you how to do some of the electrical
