I'm so torn. I have mine just sitting in my garage, but I don't want to get rid of them.I'm also looking for the orange strip take off. I hit a turkey. so if anyone is willing to sell please let me know.
I have not found a part number yet... Maybe you could see if there is a number on yours.I'm so torn. I have mine just sitting in my garage, but I don't want to get rid of them.
Just the thought if these lights ever break or something like that where I would have them to fall back on.
How much are they through the Ford parts site? Has anyone checked?
Sure enough. Different part numbers for each side.I have not found a part number yet... Maybe you could see if there is a number on yours.
Those P/N's bring up the whole grill priced at $650.
Weird, why is there a left and a right if they both go to the same thing.Those P/N's bring up the whole grill priced at $650.
That's possible; I discovered ages ago when trying to locate parts for 50 year old cars that the number on the part is usually a casting number or sub assembly number. The actual part numbers were listed in the dealer parts manual.It’s probably a valid part number. One ends in 06 and the other in 07 but the first half is for a grille. May not be available separately.
Now all I gotta do is wait for the next batch of amber light bars I guessThat's possible; I discovered ages ago when trying to locate parts for 50 year old cars that the number on the part is usually a casting number or sub assembly number. The actual part numbers were listed in the dealer parts manual.
Congrats on the install looks Great!!Finally got mine installed. Been too busy having to go to work.. I was apart of the 2nd batch, actually got these before I got the truck.. Took my time to do them. Looks very cool![]()
and happy how it turned out.
You haven’t missed it. I just was working on listings earlier and made that one active with no stock. Prepping to do the next round of orders.Add me to the list for next batch please. Looks like the next order is sold out already.
Cool. Thanks.You haven’t missed it. I just was working on listings earlier and made that one active with no stock. Prepping to do the next round of orders.
I don't think it would be too complicated. Putting a housing on myself is worth not drilling any bigger holes into my expensive truck lolAs I take in feedback from all the current owners, one of the biggest pain points seems to be my current 3 pin molex connector between the light bars and the voltage regulator boxes. I never liked this connection as it’s not waterproof and it seems to be rather fragile since a number of folks have broken the connector or a pin in the process of removing the connector housing to feed the wires through the prescribed hole in the grille.
I want to make that connector a waterproof connector but that inherently makes it bigger and likely harder to take apart for most people which would mean a bigger hole needs to be drilled in order to pass the whole connector through the grille.
I could crimp the pins onto the wires and provide the housings to assemble the connectors after feeding wires through the grille. The assembly is pretty straight forward and only requires a flat head screwdriver.
I guess I’m looking for opinions on if this would be too complicated? Is a better connector truly valuable to folks?
I would be doing the same connectors on the plug n play harnesses as well.
I appreciate everyone’s feedback as I try to continue to improve on the design of these lights.
I would say most definitely worth it, even if price had to go up.As I take in feedback from all the current owners, one of the biggest pain points seems to be my current 3 pin molex connector between the light bars and the voltage regulator boxes. I never liked this connection as it’s not waterproof and it seems to be rather fragile since a number of folks have broken the connector or a pin in the process of removing the connector housing to feed the wires through the prescribed hole in the grille.
