I want to make this same change. I have a 2025 Tremor 402a with 3.5 L Ecoboost. Does anyone know if this same tranny skid plate of the Raptor is a direct bolt-on for a 2025? (I'm betting it is but seeking confirmation). Thanks!
I'm not sure why it wouldn't be. I did the same on at 2023 and did anything change to 2025? Nope. Just buy it and install it, what is it, $150 bucks?
Best thing to do would be to look up the part number for your Tremor splash guard and the 2025 Raptor splash guard and see if it has changed from the part number listed in the video.
Just installed Designer Trim’s color matched bug/rock guard. The color is spot on!!
Can you replace the speakers in the headliner? How?
I believe the headliner is just held up with the trim pieces and once those are removed there's just magnets.
Got the flares back from paint and tested the wiring harness I built to make sure it works. Next up is to install the rubber gasket on each of the flares, get under the truck and run the harness, then finish taping and split sleeving the wires coming off the lights in each flare. After that I will finally be able to get them installed.
Nice little project for this weekend.
Yeah, with a toddler I've been having to work on it an hour at a time in the evening after she goes to bed. The goal is to have it wrapped up by Thursday.
It will absolutely work on your 2025! I am putting one on my Father in- Laws 2025 King Ranch. Only issue with the newer model is he doesn't have the fabric splash guard so you will need actually order 4 bolts instead of two and 4 of the U-Nuts. You will need two of the smaller bolts and u-nuts that are used for the front of the splash guard as well. I listed the parts needed in my youtube video description. There is a version of the skid plate on ebay that is nearly identical and cost around $150 bucks and ships free. Much better than the current $225 dealer price...
So far I've added amber vent lights, a bullet antenna, Line-x spray in bed liner, Line-x folding bed cover, and Line-x trailer hitch. I have scheduled installation of Rough Country painted fender flares and wheel well liners next week.
Future plans are:
RCI Aluminum Full Skid Plates
Fumoto valve for simplified oil change after skid plate install
Wheel spacers to match the fender flares
RCI Rock sliders
Icon stage 5 suspension (CDEV and IIC is important)
35" tires
Winch (either ARB or Warn)
Last item would be a whipple to get a Tremor R but haven't decided yet. Wish I could get 37s on it but don't want a 6" lift.
Pics of install
Just finished up installing the Engine Bay LED Kit from F150LEDs. I really got tired of using my cellphone as a flashlight for simple tasks like checking oil or helping a buddy jump start his truck late at night. Why these super nice trucks don't come with an Engine Bay light is something I just can't understand.... Got a few minutes to watch? Getting close to that 1000 subscriber milestone!!
Today's upgrades: Bak Revolver X4S Hard Cover, Ronin Smartlock Antenna, Maxzina Rear Wheel Well Liner, and Lasfit Bed Mat. Slowly coming together!!! Next is Eibach Stage 2 lift with Toyo Open Country AT III's size 295/70/18 on my factory rims. Also adding S&B Cold Air Intake and a tune.
Had to disconnect the battery again for a half hour to get the update thing working again. I haven't driven it since last November. They took it in then because it was not updating. On the repair report I read that they disconnected the battery. I've only moved it out to measure for making my swing away hitch rack and motorcycle carrier
Not a bad idea.
looking forward to seeing these installed!
