Installed a DiamondBack cover...
I watched The Fast and the Furious and then installed some F150leds.com lights in the side vents.
"No one likes the tuna here!"
View attachment 5685 View attachment 5688View attachment 5687View attachment 5686
I installed these on the inside of the vent like so the light shines through the vent. If I did it again, I would install on the back side of the black plastic so that the light would shine onto the orange plastic.
Did you connected it to the parking lights or an auxiliary switch?
Got my standard Line-X; I'm pretty particular and think they did a great job (Line-X Central Ohio, Huntley Rd.) - removed all bolts/boxlinks (standard procedure), and even the tie down cleats at my request (going with BuiltRight bulkhead accessory rail so needed them accessible), and sprayed a bit down the back of the bed. The guy I worked with was proud of their work and walked me through everything they did and my expectations.
I popped my FORScan cherry tonight and did everything on my list.:love::love::love:
- Glare Free High Beams
- Disable Double Honk when exiting running vehicle with keyfob
- Fogs on with highbeams (bambi mode)
- Enable digital temps on engine & Transmission 12" guage cluster
- Enable Cameras at speed in 4x4 modes
- Disable Auto Reverse Braking and alert
- Disable Fake Engine Noise
Finally got around to installing my MPG caliper covers today. Love the color, but the bronze rims don't really do them justice. Might consider going with black or dark gray rims later on.
I am on their website, what color did you go with?
What do you do when you have something large to put back there? Do you take the whole thing off? Like what would you do if you had to put a couch back there?
I like these covers. I’m just not sure it would be practical for my needs.
This is my biggest dilemma.. It's really just the center section that's clamped down.
I figure it's just 4 bolts torqued at 5-6 ft-lb - I would plan on scribing or marking on the railcap where the center rail needs to be replaced. Does anyone with a Diamondback see an issue with easily removing/replacing the center rail so long as the position is marked?
The other reason I may not want the Diamondback is I saw one this last weekend and it looked so dirty while the rest of the truck looked pretty clean. We get a lot of pollen and other crap in the air here that just makes thing look dirtier than they are.
Got the new intercooler, but won't install till mid/late December....after the body shop fixes my current bumper.
Do you have the pin layout or which pins did you tap into?
Hello, I attached the RED from the Radar harness to the Black, and BLACK to the Green.
Got decals/stickers removed and full Xpel PPF done. Window tinting scheduled for next week.
You could just wire it to one of the up-fitter/aux switches. I always do it that way so I can switch it on or off whenever I want. I have a long commute, so I usually have it on for the majority of the trip (rural highways), but then I switch it off in the city so it's not so annoying.
Husky wheel well liners and Sylvania LED cool white 194 plate bulbs. Also did a paint correction and a ceramic wax. I will use this process to get me through the winter before I strip it off again and truly coat her.
Monday is scheduled for tint and AS 2 inch level install with alignment.
Husky rear fender liners. Looks so much better IMO.
