What is your wheel and tire setup?
First time posting but have been on the forum since spring last year. This forum has been so helpful in figuring out what will work/what other people are doing.
Thanks to all who have shared there knowledge and experiences!
Wheel Brand: Method 703 matte black
Wheel Size: 17x8.5
Offset: +25
Spacer: No
Tire: MT Baja Boss AT LT
Tire actual size: 35x12.50 (34.5x12.8)
Suspension Modification: Auto Springs 2.5” level
Trimming Required: No
Rubbing Onroad: No
Rubbing Offroad: N/A
Upgraded the spare as well. No issues with it fitting.
I did move my front crash bars forward before the new setup. Not sure that I needed to but it was easy enough. Used a short piece of a 2x4 and mini sledge to knock it forward.
Truck looks good 👍
Can you grab a photo front or back. Curious of any tire poke.
FYI, there is a video floating around with the Tremor crash bars. Dude backs off the bolts, push the bars out and retighten to get enough clearance for a 37” tire. Easy and quick
Truck looks good 👍
Thanks man! Wouldn’t mind a little more poke but was set on these wheels and it was between +25 or 0. Didn’t want to have to trim anything so I went with +25. Offset calculator puts them out 1.2” more than OEM. I don’t have a pic from the front showing the poke.
2" leveling kit and stock tires and wheels look good. More than happy with stock tires and wheels.
Wheel Size: 17x8.5
Offset: +25
Spacer: No
Rubbing Onroad: No
Looks good!
I have the Baja Boss A/T and method 703s installed on my tremor.
How/where did you find a 703 with a +25 offset? I have a 0 offset. It looks like you can find them online, but method doesn’t sell them directly. Thats stupid. I get a pro deal with method (30%) off, I could only order the 0 offset wheels.
This is my Part#: MR703785165
Thanks! I just checked their site and it looks like you can get the +25
Oh, well then. I guess I missed that.
The factory wheels have a +48 offset, so in either case you're moving the tire out an inch or so. I have a little bit of poke, but it's not terrible.
It's +34 offset for the factory wheels on the tremor.
I suppose I should add mine since it is finally installed.
Wheel Brand: Volk TE37 XT reps
Wheel Size: 18x9
Offset: +6
Spacer: No
Tire: Wldpeak AT4W 295/70
Tire actual size: 34.3x12.2
Suspension Modification: Icon Stage 3 w/ billet UCA
Trimming Required: Yes, wheel well liner in rear
Rubbing Onroad: No
Rubbing Offroad: No
Wheel Size: 17x8.5
Offset: +25
Spacer: No
Rubbing Onroad: No
Nice Setup! How's the poke from 25mm offset? Is it flush with the fender or just poke out a litter bit? I'm trying to get one but not sure to go with 25 or 0 offset
Thanks! Compared to factory offset and tires, this setup puts your tire out 1.2” further. There is definitely a bit of poke but not much. I was back a forth on +25 vs 0. Previous poster had the same setup but with the 0 offset and said there was rubbing. I didn’t want to trim anything so +25 it was.
Anyone running the Method "gloss titanium" or have seen it compared to the OEM wheel color? Curious how close it is - shooting for a sort of OEM+ look
Toyo ATIIIs - 35x11.50x17
Method MR703 Bead Grip - 17x8.5" - +25mm Offset, Machined / Clear Coat
Icon Stage 5 - Front Suspension Level
There should be minimal if any poke at all with this combo.
I'll post pictures once mounted to truck.
Raptor takeoffs.
+34mm offset. 17x8.5
315 70 17 KO2
Eibach 2R
Very minor rub at full lock. Haven’t take off road with these yet.
CORRECTION: no rub. It was actually the bolt from the ball joint that was touching the inner rim. I grinded it down a bit.
Off road this weekend.
Raptor takeoffs.
315 70 17 KO2
Eibach 2R
Looking good.😎
Maybe it’s just me and my OCD but do you also wish the Eibach springs were black. 🤔
Looking good.😎
Ha maybe I’ll go over the top and make them orange :P
Wheel Brand: Raceline 944B
Wheel Size: 17x8.5
Offset: +18
Spacer: No
Tire: Toyo Open Country ATIII
Tire actual size: 35x12.50 E (34.5x12.5)
Suspension Modification: Icon Stage 4 (1-3/4” lift over stock height in front)
Rubbing Onroad: No
Rubbing Offroad: Minimal on rear crash bars and rear inner fender well at full compression. Readjusted crash bars and massaged fender liner with body hammer.
Wheel Size: 17x8.5
Offset: +18
Spacer: No
Rubbing Onroad: No
View attachment 36670View attachment 36671
What is your measurement from fender to ground?
