What is your wheel and tire setup?
You can get a 315/70R18 on a Baja boss as well, but it’s going to be a far worse tire for commuting than the recon grappler.
If you’re driving on pavement a lot, recon all the way.
I drive pavement all the time with the Baja Boss ATs and they seem to be fine, BUT, I haven't tried the recons, though I was considering those initially, so maybe the ride is that much better on-road with the recons? The BB is heavier, of course, so mileage is going to be worse, but I haven't noticed much change since I switched from stock. But that +18-ish offset seems to be a sweet spot with these trucks.
Interesting that you haven't clocked a change with a tire that's 20lbs heavier....
Right? 80Lbs more of just tires isn't insignificant, but no, not much of a change... maybe 1MPG?
So my truck, from the beginning, never got up to the stated MPG. Even 100% stock. I was able to get 21mpg on the expressway once (with the Baja Bosses and heavily laden with hundreds of pounds of fuel and gear for the Helene response when I did that). Otherwise, even when stock, I got maybe 14.3, 14.7 MPG. On long road trips before changing tires I got the same, without much difference city to highway. Right now, I'm getting about 13.7 city and highway. I haven't used Forscan to adjust for tire diameter yet and fix the speedometer- and maybe that'd have an effect, showing the true difference?
I would think your MPG may actually improve after you correct tire size in Forscan, since right now you would be technically underreporting miles
Here is my 2024 Tremor with The Full Icon Stage-5 Suspension installed.
Tires: 35x11.50x17 Toyo ATIII3
Wheels: Method 703 Machined - 17x8.5" - +25 Offset
Rear Icon Springs with NO add-a-leaf with Icon Shackles and standard F150 1" Block added.
Crash Bars are not rubbed at all and did not have to be moved.
Currently has 2 1/2" Rake
35” KO2 definitely took a bit of pep off acceleration but I’m not seeing much worse mpg. The Baja boss is REALLY heavy but I want that next.
My ‘23 401a:
Wheels:
- MR703 +0 Matte Black (selling for +25 so I can get 35x12.5s, which will rub with these +0s)
Tires:
-Mickey Thompson Baja Boss A/T 295/70R17 34x12 (E)
* Actual size: 33.7x12.1, it’s actually closer to a 305 than a 295.
Suspension:
-Bilstein 6112s (+1”) + 1” spacer = 2” level
-Bilstein 5160s
-Factory UCA, alignments are good. Will be upgrading to SPC UCA once I go to 35s and 8112s/King 2.5 adj-res.
- Deleted Swaybar
Rubbing: None at full compression, full lock on or offroad. No Trimming.
* Will be upgrading to 35x12.5 once these die, and may give the 8112s a try if I can get them at a good price.
@Machine We keep winning
@Calbot If you drive like a grandpa and use cruise control, once vehicle is warmed up, I’m still getting 21-22mpg on the highway and about 17-18 city. These particular Baja Boss A/Ts are the heaviest of the bunch, weighing in at 72lbs, where the 35x12.5 weighs only 68lbs (?).
They are worth it. I can go through heavy mud in 2WD. Rarely need 4WD. My locker has only Been used once or twice.
My ‘23 401a:
Wheels:
Tires:
Suspension:
-Bilstein 5160s
- Deleted Swaybar
Those 8112 Bilsteins are very interesting indeed.
Yeah I traded to the KO2 effectively for free so once they are warm I’m gonna go Baja. I’d like to get the ford tune to get a little grunt back but also don’t feel like playing a warranty game.
I think it would as well, and I just need to get the OBD but I need a job first 😭
Got them on and had to do some minor trimming. We moved the crash bars as well.
They are 305/70R18 BFG KO3 on Fuel 18x9 +20. I currently only have a 2" puck but may need to raise the front a little more. I did some minor trimming, and it doesn't rub but when I go offroad it might.
If you don't want to trim more or cut anything you could try SPC UCAs and their cast and camber kit. I've heard it helps a lot with alignment to get everything back in spec and prevent rubbing. Halolifts sells them
