Some pretty good info on lifting an F150 2021:
Click image to watch
- Sensors and cameras need realignment after lift
- Should check torqued bolts after 500 miles then every oil service there after
- Draw a line through the bolts so a visual inspection can identify if something loosened up
- 4” Lift for 35’s
- Speedometer needs adjusting after lift (Forscan May have new tire size as a selection — I seen it on my 2019 F150 Limited when setting up Bambi lights)
Did FORSCAN have option for 35x11.5 or was it just 285/295 etc etc
Yep, I don’t get better than 14mpg on all highway with 35’ MT’s on stock wheels with 2.5 Auto spring lift. I was getting 16-17 before, also Speedo is off by 2 mph.
did you use FORSCAN to fix speedo, or just deal w/ it?
I want to switch to 17s and run 315/70R17 tires. I really like the the tire choices and performance at that size. I can't figure out why Ford went with 18s on a truck targeting the off-road community. Seems like the 18 tire selection and weight of the tires isn't that great. I'd like to get the Enkei RPT1s with D rated 315/70R17 Duratracs but worried the 12mm offset will be too much and also wonder what lift/leveling kit will be required.
Anyone know the OEM offset yet?
I'm running 285/70/17 on my 24 Tremor M/T
