2022 Tremor Changes (ex: Wireless Charger, HVAC Knobs, etc.)
Do the cup holders still have the clear lens at the bottom where the led would typically be behind ?
Having the same thought about adding your own LEDs there also?
I found these for the license plate lights:
Yea, wonder how difficult it would be.
I already ordered license plate leds also after reading the news.
@Cranbery @TxT
Me too! Found this, wonder if the parts are the same for the F150. I would figure they are??
No, the clear lens is absent.
@Cranbery @TxT
I am very interested in installing these as well! I already have those Tremor cup holder inserts too and I was pumped to use them
@Cranbery @TxT
Good find.
I’m ordering all the parts !
Good find.
Sounds like maybe the light ring could be different for our F150 2021+ trucks but all the other parts are the same as the Super Duty. Trying to figure out the light ring part#.
Someone posted the different light ring for 2021+.
ML3Z-14A318-C
I wonder why Ford skimped on the ambient lights and license plate holder lights — lame for sure.
Most likely due to supply issues.
Perhaps — I tend to the think its margin or a way to differentiate if from other trims.
Just picked up 2022 AMB 402A today, and yes as silly as it sounds this bothers me.
Cup holder lights not so much. I’ll buy a glove box wireless light.
Anyone have leads on some LED’s I can swap these out with.
These are the ones I got, should be able to just go under the truck and replace the bulbs with these, I haven't yet since my truck isn't here yet:
Philips Automotive Lighting... https://www.amazon.com/dp/B077G61NB7?tag=f150tremor-20
Nice thanks! I'm on it. Was it easy to install?
I also think I would like to try to install a light in the glove box and where the wireless charger is. I assume the wiring is removed. I suppose I could do a battery operated light.
Very easy install. The lights are accessed from behind the rear bumper. Lay on your back beneath the truck and you can reach them. Just twist the light sockets counter-clockwise, pull out the $%@! halogen bulbs, plug in the LED bulb, insert the socket back into the light housing, then turn the socket clockwise to lock it in place. Just be sure to line up the tabs on the sockets before twisting them and be sure that the gasket on the socket seals properly.
Crazy to me there's no glovebox light...
