2025 Tremor Leveling Kit
You don’t need the rear blocks for your truck??
I did not want to lower the rear. I only installed the coilovers. I left the OEM blocks on. I still have some rake, and that is fine with me. I was happy with the results 👍
Have a pic of your truck how it sits with kit on?
Here is a recent pic.
Looks really nice man but ya just a little rack still but very very minor.
It's about 1.5 inches of rake. If you end up installing those rear blocks that come in the kit, you'll have less rake than that. Maybe none.
Ok and that 2.5” RC kit it is not adjustable hey it is just a full 2.5” in front hey?
The M1 struts are adjustable, the N3 are not. I went down one position on the snap ring for 2" inches of lift.
Oh ok good to know I got the M1 ordered should be here today. Do the M1 come preset at a certain height? What’s your CV axle angles like?
It's been a while, but if I recall correctly, they came preset on the highest ring at 2.5".
I would also note mine settled almost a quarter inch after driving for a month or so. My original 2" of lift became closer to 1.75".
Awesome Info that’s a lot for help hoping to get mine on tomorrow.
I'm running 2" Auto Spring Tremor specific puck's. Vehicle aligned without issue, drives no different than factory, cameras and sensors work fine. I will likely upgrade to a Halo package when the factory shocks wear out.
I'm going to give these a whirl for my 2024 F-150 Tremor. I don't have the tools or knowledge to DIY. Will the dealership put them in and do the alignment or do I need to have someone else put them in and then go get it aligned?
FWIW. I had 2.5” and 2.0” Auto Spring Tremor spacers on my 2024 and the UCA hit the shock mount at full droop in both cases so I took them back off. I think they would be fine if you aren’t doing any off-roading or urban parkour.
I had a local shop do it along with the alignment. Some dealerships will do it.
I checked with the dealership where I bought it and they don't, but gave me another local dealership recommendation. But, the person I talked to cautioned me about doing this could louse up the ABS and/or wear out the U-joints unnecessarily. Should I be concerned?
