2025 Tremor Leveling Kit
Was questioning this too. The Ford dealer has been doing this to many of their trucks on the lot with this 3" kit. The Ready Lift kit came with an upper control arm to help mitigate the angle. Not perfect but it helps. I packaged the kit in with my purchase. If they didn't endorse the setup - I wouldn't have gotten it. Sounds like many dealers err on the side of caution with them.
Have a pic of your CV angles I am interested.
These 3 inch kits on the lot, are they Tremor or regular F150? Also, the dealer isn't concerned with anything more than selling and fixing vehicles. If they create a situation where the vehicle will need to be repaired sooner it is a win for them.
They also had it on another 401 Tremor on the lot. There were some XLT's with the Ready Lift but guessing they were prob less than 3". They did have the control arm.. if they were 3's.. perhaps a block was added to the rear. Not arguing this is risk free.. not for everyone. Think the kit has been out for a couple years from Ready Lift. I was more concerned with it messing with Blue Cruise but everything is functioning as it should.
Here's the link to the kit: https://www.readylift.com/3-front-lift-kit-2021-2024-ford-f-150-tremor-models-2.html
3 inch lift with OEM TREMOR shocks?
Weird.
Do you know if lifting the front end 2.5โ€ impacts the sensors or cameras?
I leveled up 3" on my 2025 402 and no issues. Sensors, Camera's, Headlights, and Blue Cruise all work fine.
Those are not crazy bad CV angles. What size rims and offset and tires size you running SKTerm??
This would be the kit you want with hey?
Yeah that's the one.. says it's not compatible with Blue Cruise, but everything works fine on my truck. The steering is not that smooth stock feel anymore but nothing I would complain about ( half of this feel could be my tires too). Looks pretty dead level. I would not recommend to people who tow or often have heavy payloads as she may reverse squat.
The rim is 20x9 +1 offset. Tires are 295/60/20. I thought there would be rubbing.. nothing yet. There could be rubbing reversing at steep angle.. but not once have I heard or felt anything at full turn.
What brand and model of rims they look really nice.
Thanks! Was looking for a long time.. then I randomly went to Fuels site and my eye caught these - new for this year. They are called Hammer Heads (blackout). Was thinking they would look really good with the white. I was unsure of moving up to a 20" rim.. but I don't really leave the pavement. I'm really happy with the setup!
Here's the link: https://www.fueloffroad.com/fuel-1p...bPfFUlN_dRF6SaB452pxcgrF529PvPOGD1JfZDUisMtZ0
I had a local shop do it along with the alignment. Some dealerships will do it.
Will I have to get the cameras re-aligned with the 2.5" AutoSpring install? Anybody have experience with that? Does doing this screw anything up with the 'Auto Scale' system?
It depends on your use case but for most an adjustable 2.0 coilover is great. Shoot me a message and Iโ€™ll get you dialed!
Hey there Iโ€™m tryna do the same thing with mine but my 2.5 puck isnโ€™t leveling my truck it needs at least another 1/2โ€ to be level! Whatโ€™s your suggestion?
Running 3โ€ on the tremor is going to max out all your angles, I would not recommend doing more than 2.5โ€ max.
So I just got a 2025 F150 tremor. I want to level it so I took it down to a shop and they said the only kit out is a rough country one. They said that rough country doesn't make good products and the steering will tighten up tremendously.
They recommend BDS but they don't have one.
Anyone recommend a good leveling kit for their 2025 tremor?
Auto Spring kit (tremor specific)
2.5 max stretch imo for a spacer
if you want the truck " level " you need to replace the rear blocks with smaller ones....
or use shorter shackles...
I'm running XD 20x10-ET-18 O/S They poke out about 1-1/4" on my 24 Tremor 275/60/20 there just over 33" M/T no rubbing and I'm stock.
By far the most popular is the Eibach kit and most people are very satisfied with it.
Speaking for myself, I prefer the Bilstein 6112 setup with the matching 5100โ€™s.
With that being said, there are other kits available from other brands such as Fox, King, Icon, Halo, and others.
In the end, it usually comes down to how much money one wants to spend.
The eibach kit works for tremors?
