SpaceWhiteF150
You are correct, if you fully remove the center trim piece you will have plenty of room. Bit of you run the eco trim piece with the factory license plate bracket it gets tighter.The SS3 is 3.3” square and I’ve got 3.75” each side the plate. Is there any other reason why it would not work?
Thanks
But you’re right it looks like it would easily clear. Since you have close to 4”. Do you mind if I save this pic to show others?
Thanks, Connor
