SpaceWhiteF150
Install instructions other details and orders will open this weekend!
Next time I'm outside I can get some pics of what I did. It's awkwardly stiff plastic to trim so I'd recommend a plastic cutting blade or a hole saw.Eco Owners
From my research you would have to trim both sides of your intercooler shroud somewhere in the area of where I placed the red line. Please chime in with your input!
Yes my ride is a 5.0!Is the white truck a 5.0?
Can you expand on what you are referring to as trim? Would it be shaving it down, or more likely cutting a hole/slot for the bracket to pass through??Eco Owners
Yes it would be a hole or slot. It just has to be able to fit a 1.5” by .25”, preferably slightly larger to give you room to easily slide the bracket in.Can you expand on what you are referring to as trim? Would it be shaving it down, or more likely cutting a hole/slot for the bracket to pass through??
Yes I removed the long slots, and bumped it up to .25” material!Is it thicker stock over the last one?
There’s a guy in this forum made a bracket in an “L” shape… wonder if it was to make it rigid
They are almost exactly flush with the two plastic bars that run vertically on the trim piece. So ever so slightly tucked in. If you look at your truck you will see what I’m talking about!With the 5.0 and SS3’s do they sit flush with the opening and if not is it able to be shimmed and secure?
Thanks
