CHF1212
- Jul 26, 2026
- 29
- 33
- GA
- 2025 Tremor 3.5L 402A Agate Black
- Current Ride #2
- 2024 4Runner ORP
Agree. Oem replacement is what I'm going to push for. Glad to hear I'm not over reacting.
The truck has ended up way too high in the front. With the clip on #4 and a motoFab shim is a full 2" over stock. There's no way it will settle a full inch.
Aesthetically it looks good but CV angles are unacceptable. I don't like when the pleats on the boot collapse and start touching each other.
I've already zeroed the camber and toe myself. Fixing caster is not going to affect ride height by any appreciable amount.
I think I'm going to remove the shims and drop the clip ring to #3 before I go waste $160 on an alignment. That should remove 1" of lift.
What in the world caused this? The motofab spacer is a reliable 1/2" lift so it's not a suspect.
Either the KYB tophat rubber is too thick, too stiff, or the spring rates are out of spec?
