F150 Tremor FORScan
It adds detail and shadows, looks really good IMHO
So I just made these changes and went for a drive. The highbeams will dim for on coming traffic. But my adaptive lights seem to have stopped working. They don't turn with the steering wheel, and they don't dip or divert for oncoming traffic.
They definitely still do their "dance" when I turn the truck on, but I also get a "check headlamp" error now when I fire the truck up.
Any idea what's going on here?
Did you ever figure this out. I did the glare free and my headlights stopped turning. Just curious if there is a step missing or that’s supposed to happen when you change to glare free
If you as getting a “Check Headlamp” error closely check the values in the HCM.
Anyone else getting DTCs with the Glare Free enabled? No warnings on the instrument cluster, just DTCs in forscan. Everything seems to working fine.
I installed the Raptor 3rd brake light and hooked up the wire from pin 7 at the rear brake light harness and pinned wire to c2280c BCM pin 12... anyone know on forcan to enable that circuit for DRL?
Ok need some computer help I guess…..
Finally bought a laptop to download Forscan & I can’t get past this when I try to install
Any suggestions??
No more double honk!! Man that is an aggravating feature!
Made a few other changes; the unleashed screen is much better looking IMO
Needing some help though on the door open alarm chime; has anyone done that? It was hard for me to decipher the spreadsheet
@Robb1 ; can you help me here?
Also; can someone help explain to me what the “global windows” edit does?
Such a great thread!
Just remember, it only opens automatic windows. For most trucks I've seen and done it for it only operates front driver and passenger windows.
Is there a setting you can change to make the back seat windows automatic? Meaning full open or close with just one pull from the switch?
No. Well...not without finding all the proper relays and wiring everything up. Then you'd have to change any needed setting through Forscan as well as turning on Global Windows. It would probably be way more work than it's worth, but that's just my $0.02.
I more double honk!! Man that is an aggravating feature!
Set
720-01-02xx*xxx--
to “0” and you should be good.
Dont think I read this one in the thread-
Is there a way to disable the double honk when truck is turned off & key is left inside the cab?
Has anyone figured out if you can change the amount of time the heated mirrors stay on. I use them in snow and rain and gets annoying having to keep turning them back on all the time. My 2021 Subaru accent gives you options for time or continuous. Just checking with all the brilliant people and see if anyone can figure this one out.
