F150 Tremor FORScan
No, of forescan
pg18 of thread
7D0-09-01 x1xx xxxx
7D0-09-03 xxCx xxxx
IPMA
706-01-01 xxxx xxx9
SCCM
724-04-01 xxx4 xxxx
IPC
720-01-01 xx8x xxxx
720-10-01 xxxx xxx3
HCM
734-01-01 xxxx xx01
734-01-02 x3xx xxxx
734-01-04 xx53 4E
Thanks guys so much for sharing this valuable information. I'm new to the forum. Just got my FIRST truck after 50+ years driving sedans :)
I have Tremor 402A package. Trying to do some mods using ForScan, but I get some errors. I'm not sure if I'm doing something wrong.
When you say for example:
706-01-01 xxxx xxx9
The format shows xxxx xxxx xxxx
so I should do xxxx xxx9 xxxx
that's what you mean?
Also, when I apply some changes, it gives me an error saying the checksum is wrong. I was not able to do most of the changes except disabling the horn when leaving the car
Am I doing something wrong? I'm using the latest ForScan software and this adaptor:
706-01-01 xxxx xxx9
Yes
Is there any way to change the order of the drive modes? I’d like to have XXX/Sport/Normal/Eco/XXX.
Kind of on this topic of changing the dash display. I know the Raptors have a little sportier looking display. Do all trucks have this and it could be turned on or off via forscan or is it a software upgrade they download per build.
I enabled cameras at speed, digital temperatures, and Glare Free lighting. They all seemed to program correctly. I’ll take it for a drive later and see if everything works as advertised.
Thanks for the information. I didn’t know GFL was available until I read about it here. I’m looking forward to trying it out. The headlights on my 2007 were terrible.
Everytime I try to write to the BdyCM Module, it gives me an error: Writing blocks failed - incompatible configuration
I have Temor 2023 with the 402A package. please help
Try the beta version of the app. Scroll back several pages there should be a link.
Are you saying that the Raptor dash when in normal drive mode looks different? The ones I have seen look the same as ours when they are in the same drive modes. They do have an additional drive mode though of Baja
In general their display has a slightly different look. I noticed when I was riding in my friends. It looks like this in any of their drive modes.
That pic shows Baja mode, which we dont have. I have not seen a difference in the display when in the same drive modes we have, but maybe I have not paid enough attention
I know the google pic I posted says baja but i've driven in my friends in normal mode and it has that same gauge look. Has a little more character than stock.
In theory then you could figure out which lines correspond to the dash display and change it via Forscan
Due for another service on Tuesday, has anyone actually had the dealer mention anything when using Forscan?
I reverted everything back to factory for the last service, but I've added some things since then and I'm feeling lazy. I have digital Temps, Bambi Mode, double honk delete and glare free headlights.
Personally never had an issue, and I’ve never reverted things back before a service
Reactions: TJE
My last four vehicles I have never reverted back to stock. My first service on the Tremor I had already done all the changes. My dealership has never said anything or changed anything. I even had them recalibrate the cameras and sensors and nothing changed. I was worried I may loose my speedo changes, but nothing. I have always been told to take a tune out, but not ForScan.
Reactions: TJE
I'm unable to use FORScan. I purchased the recommended device: https://www.amazon.com/dp/B081VQVD3F?tag=f150tremor-20
and it gave me errors writing. I then returned it and got this one: https://www.amazon.com/dp/B01F0GVBWY?tag=f150tremor-20
but it was not recognized by FORScan. someone here advised me to install the BETA version which I did, but it still not working.
The only mods that I was able to do are:
- Driver & Passenger seatbelt minder status off
- Double horn honk disable.
I would like to apply more mods like:
- Global window open/close
- Bamby mode
- Reverse Tilt mirrors
- Autofold mirrors Lincoln style
- Powerpoint timeout disabled (for my car fridge to stay on)
- and more
but I can't apply any of those!
I have F-150 Tremor 2023 with 402A Package
Any help will be appreciated
