F150 Tremor FORScan
The thing I'm interested in is the pro power and if there are any potions with that.
What would you like to do with pro power? Silence that jet engine…I mean fan in the back?
There is a TSB for that and it is a “software” update. I did it myself a few days ago with FDRS. It does make changes to the as-built and that maybe all it does, but it quiets it down. Much better now.
I can run a pre update and post update comparison of both as-built and calibration. If the changes are only as-built I can supply the changes necessary to everyone.
Is there a thread showing the 401a options or will the same ones be available as above? Minus the headlight steering.
Everything discussed in the thread should work for you Except the glare-free headlight mod (which has been the majority of the discussion). Unfortunately the 401A has completely different headlight hardware which to my knowledge is not capable.
For the pro power, I need to learn what configuration options there are to see if there are things like battery size, power output controls/safeties, etc. Things that push the intelligent and safe use of forscan.
I would be interested in this! Loving all the changes that you have given us so far @Robb1, thank u sir🍻
So do I have to pay hundreds of $$ to get the FDRS to update it myself? Is there not a way to get a free software update?
Sure thing. As soon as get a little quite time around here I will do the comparison and let everyone know what I find.
No not at all. I just happen to have the required interface and the cost of a 2 day license for FDRS to update everything that has a module update available was worth it to me vs. a dealer visit. This being one of the updates that was important to me.
you can take it to the dealer and complain about the fan noise. They will preform the following TSB / SSM:
Manufacturer Communication Number: SSM 50167
Summary
Some 2021 F-150 vehicles equipped with a 2.0kW Pro Power Onboard inverter system and built on or before 22-Nov-2021 may experience a loud fan noise emitting from under the rear seat. This may be due to various software parameters in the direct current/alternating current converter module A (DCACA). A 2.0kW Pro Power Onboard inverter system is identified by: DCACA inverter assembly being located in the cabin under the rear seat on the left side of the vehicle. To correct the condition using the latest level of Ford Diagnosis and Repair System (FDRS), reprogram the DCACA module. For claiming use causal part number 19G317 and applicable labor times from Section 10 of the Service Labor Times Standard (SLTS) Manual.
It may just be as-built changes however which we might be able to accomplish via forscan.
Edit to add: It could in theory be rolled out in a OTA, but who knows if and when that will come down the pipe.
Reactions: JPO
To date I haven’t seen any mapping for the DCACA module that controls propower. We can see the as-built settings with forscan, but currently have no idea what they do specifically. I hope in the future we have more info to work with which may open the doors to some mods.
Summary
Thanks!!
Following up on the pro power noisy fan:
I preformed the update from SSM 50167 on the DCACA module using FDRS (the same thing the dealer would do). The image below is the pre-update values (blue) vs. the post update values (green). In addition to the as-built changes the calibration also changes. Most likely the calibration enables the additional as-built values that were added. However, if someone is willing to be a guinea pig and test the as-build using forscan on a non-updated truck to see if it quiets the fan noise it may help other members avoid a dealer visit.
7D0-09-01 x1xx xxxx
7D0-09-03 xxCx xxxx
IPMA
706-01-01 xxxx xxx9
SCCM
724-04-01 xxx4 xxxx
IPC
720-01-01 xx8x xxxx
720-10-01 xxxx xxx3
HCM
734-01-01 xxxx xx01
734-01-02 x3xx xxxx
734-01-04 xx53 4E
Just Finished doing this, thank you!! This is awesome! Had a nice hour and a half night drive with mixed backroads, city, and highway. Anti Glare headlights are AWESOME!!
Great! Happy to hear you are enjoying it.
New mod for those interested:
Add Offroad pitch and roll IOD.
IODs are the display cards on the right side of the center display / touch screen.
APIM 7D0-01-03 xxxx xxxx 3x
7D0-09-01 x1xx xxxx
7D0-09-03 xxCx xxxx
IPMA
706-01-01 xxxx xxx9
SCCM
724-04-01 xxx4 xxxx
IPC
720-01-01 xx8x xxxx
720-10-01 xxxx xxx3
HCM
734-01-01 xxxx xx01
734-01-02 x3xx xxxx
734-01-04 xx53 4E
Where are you in NC?
Nice. I plan to buy Forscan tool when my truck arrives. Now I know who to call if I screw it up
Happy to help if you run into any trouble. You are going to like the truck. Hopefully you get your order quick!
Thanks, I am excited. March is the estimate.
Can Forscan set the rear door window switches to one touch? It's a total pet peeve of mine, my work car is a base 2017 Escape, had a window sticker of $22k, and even that has one touch rear windows, just really surprised that a 402A doesn't have the feature.
My wife’s escape same thing. My loaded Lariat only front two. Doesn’t make any sense.
