Nice. The true test for me was my wife has no idea it's been lifted or the ride changed. Score! My kid came from school and said, "Truck looks taller!", good eye.
Greetings to all! I have a set of ADS 2.5 resi coil overs and 2.5 resi rear shocks for sale with 2500 miles on them. I bought them with the plan of turning my rig into a daily driver/ camping vehicle, but since then I bought a Land Cruiser. I am selling my shocks and returning to the leveling kit I had before. These are overkill for my daily commute... haha. They are an awesome shock and have adjustability up to basically level (close as you can get with this rake) DM me if anyone is interested and I can ship them wherever. See attached pics of them on the truck
PM me if interested
Motivated seller, two seperate threads. Maybe try the for sale section?
Edit: Three threads....
Any more coupon codes for the halolift?
If you are ok with the coilover springs being silver, you can use code silver at checkout to get 15% off! If you prefer the black coilover springs then you can use tremorspec at checkout. We are trying to get rid of the silver springs so that’s why they are on sale. When we run out of the silver springs then that sale will be discontinued.
We redid our website and in the transition from the old to the new website, we lost all of our coupon codes. So the new coupon code for this forum is tremorspec.
Is there a way to add in icon leafs or Deavers to a 2.5 kit?
Are they the same spring rate and such? I noticed that they are eibach and not elka. Any difference in ride?
Chatted with Kevin. All the same spring rate. Went ahead and pulled the trigger on the silver ones. Should look nice on the silver tremor😎
What didn’t you like about the Deaver ride height?
I lost over an inch and a half. We are still working on making a (LEAF) spring that can support the weight of a canopy/ heavy RTT. What you tend to find is the higher you make the spring go up, the worse the ride.
That's odd. I was sent the silver and asked what
how high did you crank them up too? Did you lift the back too... or is that stock block? Looks great!
It was set 2.5 from halo front. I ordered the 2.5" rear based on recommendation. Found out the stocks are tapered like the raptor only smaller - 2.25-2.0".
I put the stock back in and lost less than .25" lift
Whats the major differences in the mountain kit and the IFP kit? Also, if im planning on runnings 35s do I need to get the upgraded upper control arms?
Whats the camber kit used for and would I need that as well?
Why did you take the 2.5" blocks out? I see you have them for sale..
Any difference between the silver springs and the black spring, besides color? Spring rating, compression, diameter, etc??
I confirmed with Kevin that they are the same spring rate and diameter. Looking to install next week.
