Leveling Kit
Looking Good!
I'll probably follow in your footsteps when my truck gets here. I plan on sticking with 33s though i may swap out the general grabbers for something with stronger side walls
i feel like the amount of effort required to move up to 35s is not worth it currently, i'd rather just move from an F150 Tremor to a F250 Tremor after next years redesign (assuming i even get my F150 Tremor before then)
Looks like it would support 35x12.5 R18 now... definitely 295/70 R18... assuming stock rims.
As you get some miles on it, it'll settle about 1/2".
If it doesn't settle, it looks like he picked up 0.5" over what people have measured with the Pro Comp from the ground to the fender earlier in this thread. 38" stock and almost 41" lifted. There could be slight air pressure difference as well.
Looking Good!
Same RC will be installed on mine tomorrow
Stock set up just measured to compare to Kaboom at 41.5” after installed.
Passenger is 38.6” and Driver just under 39”
So if I achieve the 41.5” after install means this kit does raise/level a legit 2.5-3”!
I’ll do some before/after measurements taken from center of the wheel to be best accurate, but definitely reassuring now given the concern that this kit would not raise a factory lifted Tremor an additional 2.5” as advertised.
Can’t wait to have my truck with this kit and 35s!
PS Measured coilover from bottom mounting bracket to top and right at 24”. I’ll measure factory one once removed tomorrow to compare
That last picture could use a couple inches too. Haha 😆
Haha! I thought I edited and deleted my 38 cal since accidentally posting! 😀
I'm totally with you on this.
I want to make sure what I put on the truck is quality and wont harm the works. But man I want that level look sooner than later. I think I'm going to get something for the short term and save up for some quality coil overs once things get a little better established and I can make sense of the different heights on the tremor as compared to other F150s.
I'm thinking either the Pro Comps or the Auto Springs. The Auto Springs are tempting because I can do them myself.. which really brings the price point down.
Update: Just purchased the Auto Spring Offset 2.5. Will post pictures when I'm done with it.
Yeah, I’m really curious to see how yours turns out. That seems the best/cheapest short term option. I think that’s the route I want to go until I’m sure the coilover I want to go with.
The Vertex would be a huge upgrade, but not a Fox, ICON,King or Bilstien. You can get the entire 3" Vertex kit with rear Vertex for $2500.00 or so. Might be a great option to get by with. That would be 1K less than the Elka kit.
I hope all goes well and you are happy. I was scheduled with one shop for install tomorrow but they messed up my buddy's alignment 3 times so I changed shops and bought myself another week to order the rough country kit and proper tires. Anxiously awaiting for feedback!
RC coilovers Installed (no rear drop block added) and I love how it turned out to! Dealer also had a factory Tremor on the lot, so had to take some good side by sides. Will take measurements at home to confirm added lift.
35x12.50 clear (barely) but can confirm zero cutting or trimming with a 20x9 +19 offset
Pics have the rear end down a little compared to stock Tremor with 400+/- lbs the bed so I’ll get some better pics and full review tomorrow after driving it around town all day.
Hope this helps any of y’all looking for options on your set up!
Looks fantastic! Great pics, the hood to hood pic really shows the lift increase and the tires look sick, well done. Lemme know how it goes tomorrow if you really like how the front end feels I might have to order that kit for my lift appt next week and let the tech decide what looks better the RC strut lift or Auto Spring level.
wow that turned out great. Making me even more excited. RC coils sitting in the backseat waiting on rims to arrive hopefully monday then a date with local shop to install along with the 295 70 18 cooper st maxx tires they have waiting for me
Looks good keep us informed about the ride, if you have a chance to check it in off-road conditions to insure no contact and that your still getting full travel would be awesome as well. It can be fine on roads but run into issues when the terrain gets uneven, that's I will wait to see what the outcome is. Well that and if I say I need to get anything else for the truck my wife might just have a negligent discharge of her handgun.
Mental note don't teach your wife how to shoot, plus definitely don't run her through mag change drills etc.
Looks killer, those tires put it over the top. All these amazing leveled Tremors just add to the pain of waiting.
ooo la la
looking forward to getting mine installed!
Winner winner chicken dinner!!! Now I have to get bigger shoes for mine.... 35x12.5" tread-envy and such.
Thanks everyone! Def love the outcome
Just got home and unloaded the bed to measure.
42” front
43 1/4” rear
Remember I did NOT install the rear block to drop an inch, but I think the slight rake is perfect and dead level when you have gear or materials in the bed like a truck should occasionally 😀
Faktor34 - These 35x12.50 will def rub if really wheeling it hard. I have my Bronco for that, so I decided to push the tire size knowing this will be only on some trails, sand/beach, and some mud, but nothing too crazy planned.
For those looking to wheel this hard, I would recommend a 295/70r18 or 295/60r20 as going to a 34x12 tire should give you the room needed.
More review to come on the RC kit after a few miles on it, but just driving home it felt identical to stock for ride comfort. (Seriously) could not tell the difference except sitting higher and a little MT tire humming, but these Geolanders pretty nice given such an aggressive thread. Def quieter than Toyo MT but a little louder than Nitto Ridge Grappler
RC Tremor kit install all done and looks fantastic, and… it rides great!!! Alignment went perfect and I think it rides even better than stock now. I did not install the rear lowering blocks so there is still 1.5” diff but it’s not really noticeable IMHO.
Looks awesome, and pretty level. With a little room if you keep any weight in the back! Very nice
looks pretty badass! One of my favorites I've seen so far
42” front
43 1/4” rear
Looks like these measurements are with your new tires. Did you take any with the stock tires? or center of hub to fender? When you say it will rub off roading, what will it hit? The crash bars? Your truck and the stone gray one with bronze wheels are on the top of my list. Thanks for all the pics and measurements .
