Probably not any loss, especially if it gets good ride reports. If you install the rear blocks you loose 1.25" of height in the rear. This is a positive to some and others will skip this step.So, what’s the performance loss with the RC kit? I’m new to this game.
I wasn’t very familiar with the BDS kit but just spent a few minutes researching. Would you the the $2,300 4 kit, or the $4,300 4 kit with coil overs?More than likely I will not be installing this kit. I am trying to figure out if I can install the 4" Fox DSC Coilovers from BDS and set the ride hight down. If not I will probable go with the Elka 3" coilover or bite the bullet and do the 4" BDS kit.
If I go with the BDS kit I will go with the Fox coilovers with the additional DSC valving. I think its another $500.00 on top of the coilover kit. You can buy and add the coilovers to the standard kit at anytime. My heart ache with the kit is cutting the frame. It's permanent and can't be welded back together. Plus you have to use an 18" or 20" wheel with proper BS to clear the lift knuckls. If my truck even showed shipped, I would order just the 4" lift coilovers with DSC from BDS and see if they would work without the diff drop. And if they didn't just order the diff drop lift and go all in, get the offset wheels I want and have a bigger truck than I want, but have truly usable 35's. But my goal is to build a do it all truck, tow the boat, overland, go to the mall and run the dessert. Diff dropped truck look cool, but loose a lot off roading. I hope Ford surprises us with the Raptor R can tow 10K and have 2K payloadI wasn’t very familiar with the BDS kit but just spent a few minutes researching. Would you the the $2,300 4 kit, or the $4,300 4 kit with coil overs?
It says 8-10 hours labor which I was thinking if BDS had some type of holiday sale and could get 10% off on $2,300 kit with install of $1200 be around $3,750 out the door and have a better quality kit with a warranty and do it once instead of first doing the 2.5 pro comp for an extra $750 with labor and still end up doing the BDS kit.
Looks greatTurned out exactly how I wanted. The ride is also better. Installed the rear blocks also.
Gotcha, I did not know it requires permanent frame modifications. Knowing that I’m most likely not going to be doing that. I bought my leadfoot 2 weeks ago used with 6k miles to hold me over till my special order Tremor is built and delivered which I have a feeling might be over 6+ months. I received order email 3 weeks ago and nothing since which is common and might not receive any update for another month or two, or threeIf I go with the BDS kit I will go with the Fox coilovers with the additional DSC valving. I think its another $500.00 on top of the coilover kit. You can buy and add the coilovers to the standard kit at anytime. My heart ache with the kit is cutting the frame. It's permanent and can't be welded back together. Plus you have to use an 18" or 20" wheel with proper BS to clear the lift knuckls. If my truck even showed shipped, I would order just the 4" lift coilovers with DSC from BDS and see if they would work without the diff drop. And if they didn't just order the diff drop lift and go all in, get the offset wheels I want and have a bigger truck than I want, but have truly usable 35's. But my goal is to build a do it all truck, tow the boat, overland, go to the mall and run the dessert. Diff dropped truck look cool, but loose a lot off roading. I hope Ford surprises us with the Raptor R can tow 10K and have 2K payload![]()
I have a feeling before long you will see Tremor specific coilovers or at least a suitable setup that allows full use of travel while being able to run 35s. RC has already came up with one solution.Gotcha, I did not know it requires permanent frame modifications. Knowing that I’m most likely not going to be doing that. I bought my leadfoot 2 weeks ago used with 6k miles to hold me over till my special order Tremor is built and delivered which I have a feeling might be over 6+ months. I received order email 3 weeks ago and nothing since which is common and might not receive any update for another month or two, or three. I wanted to lift the current tremor but don’t want to make any permanent modifications or spend BIG $’s until I know for sure if I’m going to be getting my new truck or keeping this one. I prefer leadfoot color but wanted the torsion front slip and work surface and received the good 4% under costs on new tremor order from Chapman. I think I’ll just do my scheduled Pro-comp scheduled lift this coming Wednesday and enjoy that for now and see what happens as the year progresses. I’m about an hour from Uwharrie and am looking forward to running those trails throughout the year. I hope the 2.5 Pro comp makes trailing more capable than stock, I don’t believe someone as ran a trail before and after to share the results. That Raptor R will be a beast but I can’t get a vehicle that requires Premium gas when I can get Regular gas covered thru my job. I’d lose a $600+ monthly benefit and add another $200-$300 more on top for price of gas difference. That’s why I passed up the TRX was the Premium gas requirement.
Hey natef, my RC coilover kit will be installed tomorrow so I’ll get you some feedback before you get back to help with your decision on what route to take.Looking at purchasing and installing the RC kit and won't be changing rear blocks. A little rake isn't so bad. I'm under the impression that the coilovers are the 3" (or is it 3.5?) from RC for 21's? Trying to avoid buying parts I don't need. Also looking to run 305/70/R18 or 295/70/18 KO2's/similar tire on stock rims. I am at sea for another 2 weeks and will most likely sit here and see how it works for everyone else prior to ordering. Anyone DIYing this?
I'm totally with you on this.I’m really thinking about just doing the auto spring offset spacer for now and within a couple years once the dust settles with all the options and uncertainty…I can then make a better informed decision on what to get strut wise.
Measurements as promised… 43” rear and 41.5” frontRC Tremor kit install all done and looks fantastic, and… it rides great!!! Alignment went perfect and I think it rides even better than stock now. I did not install the rear lowering blocks so there is still 1.5” diff but it’s not really noticeable IMHO.
Looks fantastic!! Mine goes on tomorrowMeasurements as promised… 43” rear and 41.5” front
Looking Good!RC Tremor kit install all done and looks fantastic, and… it rides great!!! Alignment went perfect and I think it rides even better than stock now. I did not install the rear lowering blocks so there is still 1.5” diff but it’s not really noticeable IMHO.
Picked up almost 3"...Measurements as promised… 43” rear and 41.5” front
