- Apr 23, 2022
- 143
- 216
- CA
- F250
- Current Ride #2
- GT500
Rigid industries d-series midnight editionWhat hood lights do you have?
Any increase in wind noise with those?Rigid industries d-series midnight edition
NopeAny increase in wind noise with those?
How do you like the Kings? Have you taken the Kings off road and did you swap out the upper control arms? Thank youWell I searched all the info on the web and decided to pull the trigger on a set of Raptor tires and wheels. My truck has a moderate 1.5” to 2” level from the King’s that I installed. I found a set of takeoffs that had only 250 miles on the tires so I grabbed them. Couldn’t wait to find a tire shop on Saturday so I put them on myself. I’m very pleased with the fit and look of these 2022 Raptor wheels. There is plenty of clearance in the front for the wheels to turn to full lock both ways. $2200.00 was well worth it. No rubbing, no worries all goodView attachment 6623View attachment 6624View attachment 6625View attachment 6629
View attachment 6630View attachment 6631
where are you located? I will have a set of 5 beadlock takeoffs from a 2021 raptor Shortly if your still lookingGreat look! I am currently looking at a set of raptor bead lock wheels for my tremor as well. Does your tremor have the max tow package?
I keep reading stuff about problems with 17-inch wheels with max tow package.
Yes I do take it out in the desert and do high speed and low speed runs and the Kings handle it all perfectly. Much more control in the rough stuff and much better feel at speed.How do you like the Kings? Have you taken the Kings off road and did you swap out the upper control arms? Thank you
very nice after search on google i found this topic i want to do the same but i have question do u have only auto spring 2 in the front ? did u make other mods to the rear , crash bar ? can u capture ur car in different angle pls .. thank uView attachment 15814
I had to go the same route. 2 grand for the combo. Would have been the same cost for just tires. These wheels in my opinion look better with stone gray than the stock wheels.
i only have the 2" auto spring up front. At some point I will do the front but for now it's fine. The only thing I had to do up front was zip tie the fender liner tighter to the frame. As far as the rear, these are direct replacement.very nice after search on google i found this topic i want to do the same but i have question do u have only auto spring 2 in the front ? did u make other mods to the rear , crash bar ? can u capture ur car in different angle pls .. thank u
THANK U for answer .. its great looking car..i only have the 2" auto spring up front. At some point I will do the front but for now it's fine. The only thing I had to do up front was zip tie the fender liner tighter to the frame. As far as the rear, these are direct replacement.
No, it actually seems more accurate with the larger tires.THANK U for answer .. its great looking car..
did u recalibrate speedo by for scan ?
