Tremor Level Pic Thread
2.3” Stage 3 leveling kit. Aligned great drives same as stock.
2" Ready Lift, stock wheels and tires, rear is still about 1.25" higher.
Part's, Labor, Alignment, under $600. No issues with the auto level headlights.
Going thru this thread and found your post/truck. Looks absolutely beautiful. This my color as well. How did you get such a shine? Love it!! And are your spacers Tremor specific or just a generic F150 setup?
2023 with 2.5" AutoSpring kit.
Decked drawers in the back with tools
To everyone in this thread…. If you are using spacers/pucks, are you all using Tremor specific or just F150 generic? I have been reading/searching here and other places, but really can’t find a definitive answer. Even some sellers say may/may not fit. But other sellers show Raptors are different but don’t really mention Tremors. 🤷‍♂️🤷‍♂️🤷‍♂️ Thanx for any help. 🙂
I'm using a 2" Level Kit supplied by Ready Lift.
Their Website states that it is specifically applicable for the Tremor. My kit was installed by my Ford Dealer and was the one they recommended.
Here's a link to the kit I'm running:
Hope this helps!
Hope this helps!
Thank you very much. I appreciate the response.
Suspension: (Front) Bilstein 6112s at 1" + 1" spacer = ~2 inches, 5160s in the rear
Wheel/Tire: Method 703, Mickey Thompson Baja Boss A/T 34x12
Looks mostly level, there is still about 1-1.5" of rake. I think it looks good though. Right in the sweet spot.
I am looking to replace the factory tires with those Mickey Thompson Baja Boss, size (295/70/18). I am curious on how the ride and sound is compared to the factory general grabbers.
Thanks for the information. I appreciate it. I really want that stronger sidewall and more traction in the sand which I find my myself in the Socal deserts. I do a lot of narrow trails in the mountains with lots of sharp rocks. I’m always anxious of taking out a sidewall on
The general grabber.
Did you have trouble balancing them? Did you do that yourself or have a local shop do that for you?
I am running a 1" puck from here
Thanx for that. I am slowly, but surely thinking regular F150 spacers will fit. Looking at Americantrucks.com and most of the spacers say fits all except Raptor. Rough Country included Tremor in their F150 spacers as well. Or from what I have seen anyway.
I can check with my shop later. They tried to install a regular F150 block and it didn't work, not sure what's different about the one in the eBay listing I posted above though. I would do some more research before you get in there and find out it's wrong and have to re-install everything + wait for another.
I can definitely verify that the Ready-Lift 2” Leveling Spacer works. Got a little over 2000 miles since install. No issues at all and ride quality is unchanged.
Thank you. For sure I will I intend to do much more before purchasing. But it’s weird how many places are posting “excluding Raptor”
That makes a little more sense to me. Raptors are already leveled, and they put that disclaimer there so inbreds don’t try and make the truck squat. I think it would work, but any part saying it doesn’t fit a raptor just means it’s not meant / tested on one.
Raptors have less in common with a run-of-the-mill F150 than a Tremor does.
True. Never thought about it like that. Maybe I’m an inbred too. 😂😂😂😂😂😂
I believe the Ready Lift 3” pucks are made off center to go along with the UCAs. Something I remember from the install docs.
