blksn8k
- Jul 20, 2023
- 119
- 109
- PA
- 2023 F-150 Tremor Azure Gray
- Current Ride #2
- 1975 Bronco 393W, NV3550 5-speed
My only issue right now is that my '23 has developed some sort of snapping or clicking noise somewhere in the driver side corner of the dash, I think. I only hear it if I hit a pothole or RR crossing or anything that causes the front tires to bounce. I tried spraying the door hinges with white lithium grease but that made no difference which was not surprising as I would expect a noisy hinge to be more noticeable when opening the door which it is not. My '18 had a similar cab noise but it turned out to be the moonroof tracks needing re-lubed. I haven't had the dealer look at it yet. My '23 also has a moonroof so who knows? I do have a tube of the special grease for the moonroof tracks so I'll probably give that a shot but I don't really think that's where it's coming from. It's crazy sometimes how sounds travel...Hell, I suppose it could even be a loose shock mount. I'll be rotating the tires on Monday so I'll check for loose suspension parts when I have that wheel/tire off.
Something else just occurred to me. The dealer I bought the truck from installed a Roush CAI. That's also on that side of the truck. Experience has taught me that if something goes wrong the most likely culprit is whatever has been changed from stock...
