Just curious, but why did you go with a positive offset in 18mm? I've got a set of Fuel Crush wheels coming for my '25 Lariat in 20x10 with a -19mm offset to push them outwards a bit. I'm doing what you did with the stock tires, keeping them. LOL... They only have 5800 miles on them.
Stock wheels have a +34 offset. Going to a -19, you are moving your wheels out 2+ inches. Are you lifted? If not, Id expect a lot of rub.
Would you kindly share pictures of that? Thanks
These trucks like positive offset, when lower offset is used rubbing shows up, generally the rear crash bars of the front wheel wells or the wheel well liner. I have 295/70r18 on 18x9 +6 wheels and I have polished the crash bars on the passenger side in reverse while turning. This is with a 2.5 inch front level mind you. I would think a higher lift will also minimize the rub imact. I anticipate you will have a lot of rubbing or cutting to do on a -19 ET wheel.
Well, I got the new Fuel Crush wheels installed today. Stock tires transferred over to the new wheels. They are actually -18 not -19mm offset. I did move up to a one inch wider wheel, 20x175 which is a 33inch tire. Keep in mind this is a '25 Lariat on stock suspension with no lift at all. There is no rubbing on the air dam lip or crash bars with full left or right turning. The tire shop did a great job of getting everything transferred over to the new wheels. Feels just like the stock Ford BAP wheels when driving. There's a pretty good poke which I like and after these stock tires are toast I will go with something a little more aggressive in the looks department. A set of mud flaps might be in order. I went with the gorilla lug nuts, but you can't see them due to the center caps.
Another productive day.
Added:
Diode Dynamics 3” pods using Axis Mounts mounting bracket. Thanks, SpaceWhiteF150.
Painted the front skid plate black.
She’s coming around nicely.
Planning to add those same lights with his bracket. I’m in a front license plate state too but so far haven’t put mine on. I’ll go with a similar setup though in case I end having to. Looks great
Thank you.
New window tint to match the back windows, Lastfit floor liners, and rhino spray bed liner. Trying to decide on new muffler/exhaust (not too loud and no drone) and level kit (considering Bilstein).
Might I suggest the Borla S Type exhaust system.😎
If you don’t mind a firmer ride, you can’t go wrong with Bilstein.
I would agree with Camden.. Borla S-Type for the win.. I may not have the Coyote but it sounds really great on the Ecobeast. It is drone free, sounds agressive when on the skinny pedal but remains gentlemanly when cruising. Congrats on the purchase.
Small modification but it made big difference to the look of the trick.
Images before and after
Was it a “trick” or a truck? 😂
I couldn’t resist.
