window tint
How are you liking the windshield tint in regards to nighttime driving? I've always been concerned about it but I don't think my tint guy will let me leave the shop without getting the windshield done. It for sure looks badass but I just don't want to loose visibility at night.
I am very pleased with the decision to go 50% on the windshield. Just as my tint guy said, it does not affect night time diving. Keeps the cab cool, greatly reduces glare, and just plain looks cool. When I drive my Wife's Armada with just an eyebrow done it is a stark contrast.
My Dad has 70% on his 21 Lariat, you can not even really tell it is tinted unless you look hard.
The only complaint I have is: the 12" screen turns to night mode unless the sun is shining directly on the dash sensor, the same thing happens to the 70% windshield too. I just manually set it to day mode, its a bit of an annoyance but I can deal with it.
My other concern was Police with a dark tinted windshield, this may or may not be a concern to you depending on where you live and how much the local Police care. but where I live around Memphis I would say greater than 30% of the cars on the road have dark tinted windshields and the Police have bigger problems to deal with than tint.
Hope that helps.
Hope that helps.
Nice - thanks for the feed back. Sounds like ill definitely be going with the tint. I battle many a morning with a sun on the horizon on the way to work and I think this may help a bit. Should out weight the detriment at night time.
Just set up the appointment for ceramic tint all the way around! 35% fronts, and 70% on rears and sunroof. None on the windshield, I’m not old yet but my eyes are pretending to be and I need all the visibility I can get at night!
I’m with ya and went 70% on the windshield. I couldn’t even really notice it at night after first 2 days. I’d recommend the windshield at the 70%.
My tint guy recommended against the sun roof. He said that in some instances it can cause the roof to crack. The tint changes the amount of heat that the glass can absorb inherently changing the way it expands and contracts in the process. Says it’s a non issue on panels that are more vertical like our windshields and all passenger windows but the amount of direct sun a roof gets being flat is significantly more.
We also have the sunshade and he recommended just closing it if it was too much.
Pretty honest guy to turn away some extra money…
Not trying to talk ya out if the sunroof as much as talk ya into the windshield as I think you’d really like it.
I paid $679+tax for my tint.
-Windshield Xpel XR+ 50%
-Front Windows, Rear Windows, Back Windows in Xpel XR 35%
Wanted XR+ all the way around but my installer recommended the XR for a better matched look. The XR+ film has a bluish tint that doesn’t match super well with the factory smoke look windows.
I live in Utah FYI. Price seems to vary per market.
Who did your tint? I am also in Utah and I am looking to get PPF and tint when my truck arrives.
Untouchables in Pleasant Grove. Used to be in Orem but he moved to a new facility. Owner is awesome. I have my front fascia and rocker panels done in Xpel Ulimate Plus.
Front fascia cost was $1550. Rocker panels and truck bed lower were another $900.
When my truck comes in I will be doing the same as I have on my current Lariat. 5% all around , 50% windshield with 5% brow.
Question for you tint guys. I did 70% ceramic on the front, 35% on the sides and 50% on all the rest of the windows. Nothing on the sun roof. The truck gets super hot inside even while driving. The tint guy said there is nothing he can do because the heat is coming in through the sunroof. Does this sound right? My non tinted truck stays just as cool as the tinted one. Non tint truck does not have the sun roof. any ideas?
I’m having Xpel Ceramic tint out in this Wednesday.
Planning on Windshield
Sunroof
Back Windows Clear
Maybe 35% in front which gets me close to the back so it matches.
Mainly going ceramic for heat rejection properties. Have run a lot darker in the past in my previous vehicles but the older I get the more the night driving bothers me with the darker rear windows.
Over the years, I've seen many complain that too dark makes nighttime visibility difficult. In some areas, you will get pulled over and told to remove it on the spot or get a ticket. I wouldn't go below 30%
Double check me, but I believe factory "tint" is really just dye they add in the glass making process and while it adds some privacy, it doesn't really help from a UV related heat and damage standpoint. I'm planning on adding some clear or light tint with the protection qualities I'm looking for on top of the factory "tint" for this reason.
As far as legality, my personal experience has been if you get pulled over for speeding, an energetic trooper will then take the opportunity to check your tint and, if you live in a state that requires it, ask why you're not running a front license plate!
Yes, an excuse to make a list.
My Tremor does not have the sunroof. I did tint my wife's Honda CRV. It has the rear windows already colored from factory. I went ceramic 35% all around including her sunroof and I think its 70% front windshield. We get constant sun here in Hawaii and vehicle does stay cool compared to when it wasn't tinted. I am not sure how much of a difference the tinting of the sunroof will make but I always do the sunroof just to block whatever heat that I can. There seems like a lot of heat can come from the sunroof even if you have that covered shade that is able to block the whole sunroof.
Here are some opinions of a tint shop in Canada. One talks about tinting the sunroof.
Tinting the sunroof is a necessity in Canada where UV rays are far harsher than many other parts of the world. If you spend a lot of time driving your car, you will see the effects for yourself. Your left arm that’s closer to the window may be a shade or two darker than the right, even if you wear full sleeves. This is because UVA and UVB rays penetrate right through your clothes. When you tint the sunroof, you create a barrier that blocks up to 90% of UV rays. If the days are particularly hot, the interior of your vehicle can get damaged too.
You may want to consider a darker tint to keep off the sun but do consult a professional before you do so. You may be surprised to know that a darker tint will retain more heat, hence is more suitable for cooler climates. In hotter regions, a silver tint that reflects the sun’s rays may be more suitable. Surprised? Then listen to a few more misconceptions so you know just what you need to use for your window sunroof.
Myth #1: It is easy to install a car sunroof tint so you don’t need to look for a professional.
Answer: Tinting the sunroof on cars is a common practice but it comes with several concerns. While regular window tinting in homes is easy, car sunroofs are harder. This is because, in homes, the installer simply reaches out to the window to do his job. In cars, the installer has to hang upside down inside your car. This uncomfortable position can create several errors:
• The blades can clip when they are being trimmed
• The blades can scratch the glass
• A duller cutter can create frayed edges or loose ends
• Improperly installed sunroofs may be difficult to open and close smoothly
Myth #2: A tint will shatter your car sunroof
Answer: Most cars are tougher than you think. The windows all around you, from the sides to the windshield and rear window, are made of laminated, shatterproof glass with rounded edges. However, your sunroof is made of tempered glass that will shatter so that heat is dispersed evenly. When the temperature drops, it holds shape, but in the event of an accident, the rigid surface will shatter on impact. Since the glass is made to shatter, it will crumble under pressure, whether it is tinted or not. If the manufacturer builds a sunroof that is not designed to shatter, a tinted sunroof will not give way.
Myth #3: Window tint doesn’t help with dual pane Low-E glass.
Answer: True, not all window films are suited for Low-E glass but there are certain films that are specially made for them. You need to consult professionals to install the right type of film for Low-E glass. They understand that with Low-E glass, you need lighter and clearer films that reduce the glare from the sun but does not reduce visibility in the process. You double the effectiveness of UV ray deflection if you install the right window tint for Low-E glass.
Myth #4: Cheap window tints work as well as expensive ones.
Answer: Like most products, a good brand makes a difference when it comes to car accessories too. It is equally important to choose a window tint that is effective in deflecting UV rays without clouding your vision, keep off the sun’s rays, have aesthetic appeal, and be affordable. There is no cookie-cutter solution. You need to scour the market for the right brand. The best and easiest way is by consulting a certified professional who is aware of window film technologies. They can help you choose between Dual Reflective Technologies, Ceramic Nano Technologies and Spectrally Selective Low-E car window films. Make sure you get the right technology for maximum protection.
Ceramic Pro for Superior UV Resistant Nano-Ceramic Sunroof Coating
Ceramic Pro is a multi-layerable, clear, liquid nano-ceramic coating that transforms itself on the surface to a permanent, rigid, flexible glass shield. It is an additional clear coat with three times the hardness and self-cleaning properties. Call us to find out how you can go beyond window tinting your sunroof to protect your glass like no other product.
Mine does not match at all but I did 5% over factory in the rear, 10% on the front two, 50% windshield and 5% brow, 5% sunroof
I've never tinted the windows in a vehicle before but wanted to get the front windows of the truck tinted.
What level of tint you guys doing? You just matching the back windows? Do you actually try to stay within the legal limit or don't care?
I did ceramic all the way around with limo tint on the back 3, and legal in Texas on the front 2. It stays a lot cooler. To each their own.... but ceramic is the way to go in my opinion.
I can tell you the sunroof glass gets mighty hot. I used to have an MKT and the roof often jammed when trying to open it. This required giving it a little push to get it started. I put my hand on the glass one day after the car was out in the sun all morning and wow. The glass was hot enough to burn my hand. I live in Phoenix and have a feeling that tint would certainly help here. I've seen some claims that tint could cause the glass to shatter. Others say that's total nonsense. I'll see what my tint shop says when my truck shows up.
Tinted with Xpel XR Plus Ceramic.
  • 20% fronts
  • 70% rears and back (due to the already tinted privacy glass)
  • 70% windshield
The fronts metered at 14% and the rears (with 70% + the factory tinted glass) metered at 13%. I told them to match or make the rears slightly darker and they nailed it.
  • 20% fronts
  • 70% windshield
I had 70% on my windshield and find at times, it interferes with the light sensor and turns the screens dark during the day.
I did 70% on the windshield and had the front door windows matched to the rear doors (which the shop said was 20%). Pleased with my choice.
