Then count me IN (again)As long as you have this factory lamp it is compatible. This is in both the normal and modular bumpers.
It will be utilizing a H11 plug and play harness!If you test fit these up I’d be curious to know what you need for plugs or adapters. Would you tie them into the factory fog plugs or use the upfitter switches?
One kit is out in the wild, just making sure everything works as planned! Hoping to drop them before Christmas.@SpaceWhiteF150 Do you have an approximate ETA?
That is the DD finished product!Looking good! So it that Diode Dynamics mount what the finished product will look like?
Does the kit replace the entire housing (as pictured) or just the back side mounting stuff?
I'll be keeping an eye out for them to come out! (And an eye on my wallet...)
Probably, but you want airflow around the lights for cooling. The angle of those pics makes it look worse than it does.Count me, please. Is there anyway to make a backing plate so that the gaps above and below it are closed up? Just curious.
Gotcha. I assume you will contact us with an invoice when they’re ready?Probably, but you want airflow around the lights for cooling. The angle of those pics makes it look worse than it does.
They will go up on my site!!Gotcha. I assume you will contact us with an invoice when they’re ready?
I have already worked through getting yall discounted lights!Damnit, I should have gotten lights for Black Friday while they were on sale haha.
