F150 Tremor FORScan
@Robb1 was an issue with the HCM, I guess F = 5 in my head lol, will confirm tonight that the applied changes fixed the issue, but the start up headlamp warning disappeared so feelin lucky.
You should be good to go if the warning is gone.
Thanks Rob, everything is working as intended 😬
Longshot here; but anyone in the Midland, TX area with Forscan on a PC already?
I can’t download it on my company laptop & currently don’t have a personal laptop.
Could always buy a cheapo laptop, but this would likely be the only use for it
Can it be done with an iPad?
Does anyone know if you can add the digital engine/transmission temperature readouts on the 8 inch screen? I know it has been done on the previous generation 8 inch screen. I saw Livinitup’s spreadsheet only showed it to work on the 12 inch display. Any help would be greatly appreciated!!
I also ordered a new Ford OEM HVAC AC/Heat Control with digital dial knobs…I saw there is some programming that needs done in order for it to work but don’t fully understand how to do it. Does anyone have knowledge on how to do this using Forscan?
Also thank you to everyone for contributing to this forum…I have learned so much and wouldn’t have been able to add all the cut ambient lighting / features and Forscan changes without the knowledge of the members!
Pretty sure you can only get temp readouts on the 12", on the previous gen trucks the 8" was the large screen.
As for programming your HVAC, it should just be typing in your asbuilt values and then writing those. The HVAC module is the 733 lines, and there are 17 of them, so if you do it manually it should take more than a few mins. You can also upload your AB files in Forscan without having to type them all manually. I will be doing this same thing when my truck comes in as I have all the parts ready to add the heated steering wheel back and got a digital temp HVAC since I have to swap that anyways.
100% noob when it comes to FORScan, but after reading about GlareFree Headlights...this seems like a no-brainer. Any reasons NOT to enable this feature?
Only if you hate awesome things? Lol, it’s great! Do it!
That’s a negative on the 8” screen.
For the digital readout on the HVAC module: Create a backup of your as-built with forscan before removing the old module. Once the new one is installed load the backup file.
Some discussion on the topic: https://www.f150gen14.com/forum/thr...g-in-hvac-control-knobs-for-2023-f-150.14077/
Send it!
Edit to add: the only reason not to do it is if you have the wrong headlights. If you have a 402A you are good. There are hundreds of people that have gone through with it between the various F150 forums.
It debuted here first ;)
Thank you!!
7D0-09-01 x1xx xxxx
7D0-09-03 xxCx xxxx
IPMA
706-01-01 xxxx xxx9
SCCM
724-04-01 xxx4 xxxx
IPC
720-01-01 xx8x xxxx
720-10-01 xxxx xxx3
HCM
734-01-01 xxxx xx01
734-01-02 x3xx xxxx
734-01-04 xx53 4E
Im in canada and all i see in my options is the auto high beam. How do i know if i already have that ? Thanks
If the Lighting menu says Glare Free like this photo then it is active. If you have Auto Highbeam then you will need to do the Forescan changes to activate glare free
I checked that screen and don't have that option so I will give it a try. Thank you
Trying to get forscan to work over here. I got the obdex from the Amazon link in this thread. Downloaded forscan 2.3.49, got the license activated. Installed drivers on my laptop. When I plug into the obd port I get a green light. Ignition in on pos but engine off. Click connect and I forscan cannot identify the vehicle. Help!
I am getting same message and using same version of FORScan and adapter. I just picked up my 2023 three days ago and thought it may be having issues due to new year model. What year is yours?
also a 23. 402A
