MikeJ19
stage 3 seems to have the prices out there. Got mine from them$509 for the pair? That’s a great price
Snap rings arrive tomorrow and will be on the truck Monday. I will report back when they are on. Plan is to do the second to highest setting for about 2 inches of lift.I ordered from Stage3 because they had them for $509. Looks like they are out of stock and should take about a month to ship from Fox. I ordered a week ago so should get here mid Feb. I will keep you all up to date.
Adding link: https://www.stage3motorsports.com/985-62-013-2-21-22-f150-4wd-fox-20-snap-ring-ifp-front-struts.html
I should've taken measurements. I have a 2" auto spring level, installed these in the rear, I think it looks pretty close to how it did before, maybe slightly higher. Rides so much better loaded and unloaded. With the recent storms in ca I loaded up about 1k lbs of sand and it handled it so much better. This is how I imagined the truck would ride stock.I would run these in a heartbeat if it wasn't for the added lift in the rear. I don't mind the stock rake, but adding another 3/4" to the rear would probablt drive me nuts
My ride height didn’t change at all when I installed.I would run these in a heartbeat if it wasn't for the added lift in the rear. I don't mind the stock rake, but adding another 3/4" to the rear would probablt drive me nuts
The compressed lengths of the gen 2 is not correct. They are 18.9 inches compressed so you would need to run a bump stop extension that was ¾-1 inch. It would result in a loss in downward travel.Why gen 1 Raptor shocks and not gen2 with the aluminum body ? Seems they would be valved closer to the weight of our trucks ?
Well the struts didn’t arrive until Monday night so I had to reschedule my install. Truck gets dropped off tomorrow at 9
SameMy ride height didn’t change at all when I installed.
Well now that is interestingMy ride height didn’t change at all when I installed.
Looks good. I like it. Do you have the part number for the front strut kit?
