High_Country
- Dec 26, 2021
- 367
- 504
- Oklahoma City
- 2022 Oxford White 401A
I won't get the eiback kit for several weeks. They have released the kit but don't think they have built it yet.Great tire fitment post, @Yeti.
I hate to ask this question - what does the nomenclature "ET##" mean in your posts, e.g., ET20, ET28-34, etc? I can't figure it out...
Any commentary on the ride quality of that kit yet?
Ahhh...gothca. I'm very familiar with backspace and offset (and the differences) I just hadn't heard the term "ET". But, I haven't bought aftermarket wheels in a LONG time.I won't get the eiback kit for several weeks. They have released the kit but don't think they have built it yet.
So ET 20 is the offset from the centerline of the wheel in millimeters as a positive or negative number. ie. ET0 is the centerline, ET-10 pushes the wheel 10 mm outward from the centerline and ET 34 (our stock wheels) brings the wheel inward 34 mm from the centerline of the wheel.
A lot of people prefer to use backspace instead or addition to offset. Backspace is usually in inches and is the measurement from the inboard flange to the mounting surface of the wheel. This really is easy mode for suspension companies since this value is absolute (although not very accurate) it is accurate enough for suspension engineering.
I prefer to use ET values and do the calcs. i.e. (9 inch wheel with ET 0 )/2= backspace of 4.5" same wheel with an ET +13 is basically a 5 inch backspace.
Why is this important? the further out you push your wheels, the larger the radius swing (arc) that happens when you turn your steering wheel. The further out the wheel is, the less steering wheel input it takes to touch either side of on enclosure.
OK, sorry. It's basically a shortened version of the German word Einpresstiefe "Insertion Depth".Ahhh...gothca. I'm very familiar with backspace and offset (and the differences) I just hadn't heard the term "ET". But, I haven't bought aftermarket wheels in a LONG time.
That's what she said.OK, sorry. It's basically a shortened version of the German word Einpresstiefe "Insertion Depth".
The ones you just got in?So these Eibachs are the same from the 2020 F150. They haven't worked a new set for 21s yet
I'll get them in, next week but yes.The ones you just got in?
My first thought is I'm far from the smart one here.Thoughts on if you should’ve expected a unique design for the 21+ or Tremor trim versus a ‘20 F-150?
I’m thinking spring rate considerations would be about the same (similar weights, application/use case, etc). Not sure if geometry due to tremor-specific knuckles should’ve led to a different design though.
You’re the smart one here - thoughts? Did this platform deserve a unique application?
What didn't you like about the 6112s?I’ve been toying around the idea of throwing on a set of 6112’s I have laying around but I didn’t really like the ride of them last time. Hence their location on my shelf. Come on fox and Bilstiein, get the lead out!
Put them on at 2" and adjust from full droop?They felt harsh to me. Of course it could have been the 2” motofab spacer I put on top of them. Thought process was to not preload the springs for a smoother ride but I think I ended up with about 3” of lift and crap angles. The truck, a ‘16 platty ecoboost, rode like a dump truck. I ended up putting the stockers back on with a 1.5” motofab and was really happy with the ride. Soooo…. Yea, it was probably my fault and now I think I may give them an honest chance..
