Nice! +1 for this set if it turns out to give the tremors 2.5 then.they now have a bracket to mount the leveling sensors to the billet UCA's. nothing for the tubular that i can see.
looks like the only new thing is the front coilovers. the rears are the same part number that has been out and only compatible with up to 1" of lift for standard trims. seems like we are still waiting on rears that support the tremor rear block size.Nice! +1 for this set if it turns out to give the tremors 2.5 then.
All of their stuff says not compatible with Tremor, both the headlight bracket and the UCA's. Has anyone installed these?![]()
ICON 2021-2023 Ford F-150, Dynamic Headlamp Sensor Bracket Kit ICON 2021-2023 Ford F-150, Dynamic Headlamp Sensor Bracket Kit - Icon Vehicle Dynamics
ICON 2021-2023 Ford F-150, Dynamic Headlamp Sensor Bracket Kit ICON 2021-2023 Ford F-150, Dynamic Headlamp Sensor Bracket Kit - Icon Vehicle Dynamicswww.iconvehicledynamics.com
I’m not sure about the physical arms the angles might be ever so slightly different, but the bracket for the headlights is definitely the same and would work on a tremor.All of their stuff says not compatible with Tremor, both the headlight bracket and the UCA's. Has anyone installed these?
Doesn't that bracket only work on their arms? Not trying to argue, just continuing to research options.I’m not sure about the physical arms the angles might be ever so slightly different, but the bracket for the headlights is definitely the same and would work on a tremor.
Thanks, do you know if these work with the dynamic headlights? Doesn't say that is doesn't, but that is what peaked my interest on the previously shown bracket.Their new Pro control arms don't say that they exclude Tremors, only that they won't work with Raptors.
ICON 2021-2023 F150 Tubular Upper Control Arm/Delta Joint Pro Kit - Icon Vehicle Dynamics
These tubular steel upper control arms free up your 2021-2023 Ford F-150 front suspension movement to allow maximum travel for performance shocks and coilovers at an easier price point compared to our range-topping billet components. Additional caster is built in to correct geometry to allow for...iconvehicledynamics.com
It is designed for there arms but it could technically be welded on to another manufacturer’s arm. It looks like the arms that fit with the tremor are posted below!Doesn't that bracket only work on their arms? Not trying to argue, just continuing to research options.
I have always wondered about the performance of these, I haven’t seen many people run them.Any reason why these would not work? Is there a difference in mounting on 2020 vs 2021+?
AFE F-150 Control Sway-A-Way 2.5 Front Coil-Over Kit 301-5600-11 (15-20 4WD F-150, Excluding Raptor) - Free Shipping
FREE SHIPPING! Create an Adjustable Ride Height. The AFE Control Sway-A-Way 2.5 Front Coil-Over Kit is the perfect replacement for your factory component that owww.americantrucks.com
The name is to close to Stay Away for me.![]()
Sway-A-Way 2.5 Front Coilover Kit
aFe Control introduces these Sway-A-Way High Performance Replacement Coilovers for the 14th Gen Ford F-150. These 2.5 IN diameter Coilovers feature all the same race winning engineering components that have 20+ years of testing into a specifically designed kit that will bolt directly into your...afepower.com
Here's the one listed for 21+
Lol yeah but these came about for the raptor gen 2. Apparently they are supposed to be better than the factory shocks. I don't know for certain.The name is to close to Stay Away for me.
Sway a Way has been around a long time. You will often see the talked about as SAW. They were super popular in the 80’s and in the VW off road world. Then Lance KING through his hat in the ring. With his new valve stack and user rebuildable design he dominated the off road market and a lot of the smaller builders got left behind. They still do a ton off road stuff and a lot VW and Porsche stuff. But when you think off road, KING is still KING . Rumor is SAW builds the Vortex line of shocks for RC.The name is to close to Stay Away for me.
Halo’s also provide a nicer ride, switched over from the iconsPersonal experience SAW's out perform icon for daily driver.
