- Sep 12, 2023
- 2,446
- 1,963
- GA
- Current Ride #2
- 2023 5.0 TREMOR Avalanche 402A High Package
Nice.Installed Soundskin. Now my wife can hear conversations from the back seat.
Brings back car audio memories.
Are the front tow hooks easy to unbolt?Added emblems above front fender vents as well as painted tow hooks front and rear.Color is VHT burnt copper with satin clear coat.Got the emblems on Amazon and they are metal with Vht tape pre installed.
Skid plate has spacer for the rear holes,so it will fall out as you’re taking out the skid plate.Not a big deal,just be aware.I also painted the rear tow loops and did not remove those as they are welded to hitch assy.Just masked everything.
Now THAT's how you use a Tremor! Real work! Very cool reportLove the articulation on these trucks, they are perfect for ranch work. iPhone images don’t do justice to how uneven the terrain is, but look at the tires. They tell all, my truck is a stock Tremor. Nickname my buddies gave it is Tumor. Want to give this truck to my Pops so he can check the fence lines without having to jump on the tractor that has no cab. (Texas heat makes it a bitch to be on a tractor haha) Very uneven terrain on the ranch and this truck just makes it smooth, no path is unconquerable. God Bless everyone! View attachment 46746
passenger footwell - fuse2 for ACC and fuse4 for battery iirc. some folks use one of the footwell upfitters i think but i wanted to leave mine open for other shenanigans.If anyone has installed a dash cam (I'm installing Viofo A329S) and used the hard wire kit with fuse taps what fuses did you tap into?
One for constant power and one foe accessory. Looking for the best choices.
FYI …..If you have a 2025 or newer F150, the passenger footwell fuse box is now sealed so you’re going to have to crack it open.If anyone has installed a dash cam (I'm installing Viofo mA329S) and used the hard wire kit with fuse taps what fuses did you tap into?
Yikes! Guess they don't like DIYers? Or maybe want evidence something's been accessed.FYI …..If you have a 2025 or newer F150, the passenger footwell fuse box is now sealed so you’re going to have to crack it open.
So, what if you need to replace a blown fuse? I can't see Ford sealing it totally shut. They know most people are not going back to the dealer to change a fuse unless it's got a full warranty. Do it yourselfers out of warranty will pry it open. LOL.....FYI …..If you have a 2025 or newer F150, the passenger footwell fuse box is now sealed so you’re going to have to crack it open.
You hit it right on the head.So, what if you need to replace a blown fuse? I can't see Ford sealing it totally shut. They know most people are not going back to the dealer to change a fuse unless it's got a full warranty. Do it yourselfers out of warranty will pry it open. LOL.....
