This is a great tool! thanks for sharing.
I'm not tracking with what you said above that a 35x12.5r18 tire would give more clearance over what i am currently running. the 12.5" tire would sit closer to the suspension since it is wider. .65" closer. if you go to the +6mm offset, then yes, you'd gain .45" of clearance over what I'm currently at.
the fact is that the Icon billet arm just sticks out further and is the cause of the problem. I even recently saw a post on facebook from a guy with the tubular who said he was rubbing the UCA as well and had to go with spacers.
Im not any higher than i was with the procomp spacer and factory uca and i didnt have any issues. so in my mind, the issue with the icon ucas is just a crap design and not really needed.
they market the shocks as a tremor compatible kit with the caveat that you Have to use their UCAs. and then you need to change out the wheels because their UCAs stick out further and then cause rubbing.
I honestly think i wish i had just done the spc ucas. id have saved a bunch of money and likely avoided this rubbing
I am happy with the ride quality of the icon setup, but pretty irritated at the hassle it has become and additional investment required because i chose to invest way too much money into their upper control arms. Plus the fact that i spent as much as i did on the control arms, to then have to spend more to keep the auto leveling headlight function, and then, that additional bracket isnt even compatible. i had to modify it myself to prevent the ball joint from getting snapped off. that should not be the case with a $1500 UCA setup thats part of a $5K suspension setup that is marketed at tremor specific...
sorry, end rant
